We are periodically facing CUCM high CPU caused by tomcat1 process and it leads to server crash and only resolved by hard reset of CUCM.
here is th network diagnostic result:
The following web applications have an unusually large number of active sessions: _root. Please collect all of the Tomcat logs for root cause analysis: file get activelog tomcat/logs/*
and this is show perf query class "Cisco Tomcat Web Application" result:
==>query class :
- Perf class (Cisco Tomcat Web Application) has instances and values:
_root -> Errors = 340
_root -> Requests = 524
_root -> SessionsActive = 176
I've found some java errors in catalina log file which is attached.
where can I find the causing session?
