12-20-2016 03:15 PM - edited 03-17-2019 09:00 AM
When I made any call to any route pattern that goes to a gateway SIP trunk I receive "The dialed number does not allow the call to be completed..." This behavior happens even with FAC or with no FAC nedeed calls. When the RP asks for FAC, I insert it and after I receive the same message.
I did'n receive any log in gateway when I debug ccapi inout or ccsip all.
2016/12/20 16:55:03.316|CC|SETUP|37794213|37794214|1039@SRV-CALLMANAGER-SUB|091718890|091718890
2016/12/20 16:55:03.345|CC|OFFERED|37794213|37794214|1039|091718890|091718890|SEP94D4692A27C5|Gateway_SIP_Trunk
2016/12/20 16:55:03.346|SIPT|37794214|TCP|OUT|172.20.214.10|5060|Gateway_SIP_Trunk|172.20.214.20|5060|2,100,14,1.1006^*^*|134206|56654300-8591b6c7-fa26-ad614ac@172.20.214.10|INVITE
2016/12/20 16:55:03.362|SIPT|37794214|TCP|IN|172.20.214.10|5060|Gateway_SIP_Trunk|172.20.214.20|5060|2,100,14,131.3^172.20.214.20^*|134207|56654300-8591b6c7-fa26-ad614ac@172.20.214.10|100 Trying
2016/12/20 16:55:03.366|SIPT|37794214|TCP|IN|172.20.214.10|5060|Gateway_SIP_Trunk|172.20.214.20|5060|2,100,14,131.4^172.20.214.20^*|134210|56654300-8591b6c7-fa26-ad614ac@172.20.214.10|404 Not Found
2016/12/20 16:55:03.366|SIPT|37794214|TCP|OUT|172.20.214.10|5060|Gateway_SIP_Trunk|172.20.214.20|5060|2,100,14,131.4^172.20.214.20^*|134211|56654300-8591b6c7-fa26-ad614ac@172.20.214.10|ACK
2016/12/20 16:55:03.386|SIPL|37794213|TCP|OUT|172.20.214.10|5061|SEP94D4692A27C5|172.20.214.49|50530|2,100,14,1.1008^*^*|134212|94d4692a-27c50014-45fa632b-1d9ef9dd@172.20.214.49|183 Session Progress
2016/12/20 16:55:04.449|SIPL|37794213|TCP|IN|172.20.214.10|5061|SEP94D4692A27C5|172.20.214.49|50530|2,100,18,41.250^172.20.214.49^*|134215|94d4692a-27c50014-45fa632b-1d9ef9dd@172.20.214.49|CANCEL
2016/12/20 16:55:04.449|SIPL|37794213|TCP|OUT|172.20.214.10|5061|SEP94D4692A27C5|172.20.214.49|50530|2,100,18,41.250^172.20.214.49^*|134216|94d4692a-27c50014-45fa632b-1d9ef9dd@172.20.214.49|200 OK
2016/12/20 16:55:04.450|SIPL|37794213|TCP|OUT|172.20.214.10|5061|SEP94D4692A27C5|172.20.214.49|50530|2,100,18,41.250^172.20.214.49^*|134217|94d4692a-27c50014-45fa632b-1d9ef9dd@172.20.214.49|487 Request Cancelled
2016/12/20 16:55:04.450|CC|RELEASE|37794213|37794214|1
2016/12/20 16:55:04.454|SIPL|37794213|TCP|IN|172.20.214.10|5061|SEP94D4692A27C5|172.20.214.49|50530|2,100,18,41.251^172.20.214.49^*|134218|94d4692a-27c50014-45fa632b-1d9ef9dd@172.20.214.49|ACK
2016/12/20 16:55:58.284|SIPL|0|TCP|IN|172.20.214.10|5061|SEP94D4692A27C5|172.20.214.49|50530|2,100,18,41.254^172.20.214.49^*|134238|94d4692a-27c50015-68781233-3d0c8c25@172.20.214.49|INVITE
2016/12/20 16:55:58.284|SIPL|0|TCP|OUT|172.20.214.10|5061|SEP94D4692A27C5|172.20.214.49|50530|2,100,18,41.254^172.20.214.49^*|134239|94d4692a-27c50015-68781233-3d0c8c25@172.20.214.49|100 Trying
2016/12/20 16:55:59.224|SIPL|37794216|TCP|OUT|172.20.214.10|5061|SEP94D4692A27C5|172.20.214.49|50530|2,100,18,41.258^172.20.214.49^*|134251|94d4692a-27c50015-68781233-3d0c8c25@172.20.214.49|500 Internal Server Error
2016/12/20 16:55:59.242|SIPL|37794216|TCP|IN|172.20.214.10|5061|SEP94D4692A27C5|172.20.214.49|50530|2,100,18,41.259^172.20.214.49^*|134254|94d4692a-27c50015-68781233-3d0c8c25@172.20.214.49|ACK
2016/12/20 16:55:59.242|CC|REJECT|37794216|37794217|1039@SRV-CALLMANAGER-SUB|9991|9991|0
2016/12/20 16:56:42.666|SIPL|0|TCP|IN|172.20.214.10|5061|SEP94D4692A27C5|172.20.214.49|50530|2,100,18,41.264^172.20.214.49^*|134282|94d4692a-27c50016-35e1b8b3-6adbfbb9@172.20.214.49|INVITE
2016/12/20 16:56:42.667|SIPL|0|TCP|OUT|172.20.214.10|5061|SEP94D4692A27C5|172.20.214.49|50530|2,100,18,41.264^172.20.214.49^*|134283|94d4692a-27c50016-35e1b8b3-6adbfbb9@172.20.214.49|100 Trying
2016/12/20 16:56:43.245|CC|SETUP|37794218|37794219|1039@SRV-CALLMANAGER-SUB|9999|9999
2016/12/20 16:56:43.249|CC|OFFERED|37794218|37794219|1039|9999|9999|SEP94D4692A27C5|Gateway_SIP_Trunk
2016/12/20 16:56:43.249|SIPT|37794219|TCP|OUT|172.20.214.10|5060|Gateway_SIP_Trunk|172.20.214.20|5060|2,100,14,1.1011^*^*|134295|92000d00-8591b72b-fa35-ad614ac@172.20.214.10|INVITE
2016/12/20 16:56:43.264|SIPT|37794219|TCP|IN|172.20.214.10|5060|Gateway_SIP_Trunk|172.20.214.20|5060|2,100,14,134.3^172.20.214.20^*|134299|92000d00-8591b72b-fa35-ad614ac@172.20.214.10|100 Trying
2016/12/20 16:56:43.264|SIPT|37794219|TCP|IN|172.20.214.10|5060|Gateway_SIP_Trunk|172.20.214.20|5060|2,100,14,134.3^172.20.214.20^*|134300|92000d00-8591b72b-fa35-ad614ac@172.20.214.10|404 Not Found
2016/12/20 16:56:43.265|SIPT|37794219|TCP|OUT|172.20.214.10|5060|Gateway_SIP_Trunk|172.20.214.20|5060|2,100,14,134.3^172.20.214.20^*|134301|92000d00-8591b72b-fa35-ad614ac@172.20.214.10|ACK
2016/12/20 16:56:43.279|SIPL|37794218|TCP|OUT|172.20.214.10|5061|SEP94D4692A27C5|172.20.214.49|50530|2,100,14,1.1013^*^*|134302|94d4692a-27c50016-35e1b8b3-6adbfbb9@172.20.214.49|183 Session Progress
2016/12/20 16:56:43.999|SIPL|37794218|TCP|IN|172.20.214.10|5061|SEP94D4692A27C5|172.20.214.49|50530|2,100,18,41.271^172.20.214.49^*|134305|94d4692a-27c50016-35e1b8b3-6adbfbb9@172.20.214.49|CANCEL
2016/12/20 16:56:43.999|SIPL|37794218|TCP|OUT|172.20.214.10|5061|SEP94D4692A27C5|172.20.214.49|50530|2,100,18,41.271^172.20.214.49^*|134306|94d4692a-27c50016-35e1b8b3-6adbfbb9@172.20.214.49|200 OK
2016/12/20 16:56:44.000|CC|RELEASE|37794218|37794219|1
2016/12/20 16:56:44.000|SIPL|37794218|TCP|OUT|172.20.214.10|5061|SEP94D4692A27C5|172.20.214.49|50530|2,100,18,41.271^172.20.214.49^*|134307|94d4692a-27c50016-35e1b8b3-6adbfbb9@172.20.214.49|487 Request Cancelled
2016/12/20 16:56:44.007|SIPL|37794218|TCP|IN|172.20.214.10|5061|SEP94D4692A27C5|172.20.214.49|50530|2,100,18,41.272^172.20.214.49^*|134308|94d4692a-27c50016-35e1b8b3-6adbfbb9@172.20.214.49|ACK
2016/12/20 16:56:44.987|SIPL|0|TCP|IN|172.20.214.10|5061|SEP94D4692A27C5|172.20.214.49|50530|2,100,18,41.275^172.20.214.49^*|134311|94d4692a-27c50017-705e2b41-458c0d8b@172.20.214.49|INVITE
2016/12/20 16:56:44.988|SIPL|0|TCP|OUT|172.20.214.10|5061|SEP94D4692A27C5|172.20.214.49|50530|2,100,18,41.275^172.20.214.49^*|134312|94d4692a-27c50017-705e2b41-458c0d8b@172.20.214.49|100 Trying
2016/12/20 16:56:45.915|CC|SETUP|37794221|37794222|1039@SRV-CALLMANAGER-SUB|9991|9991
2016/12/20 16:56:45.917|CC|OFFERED|37794221|37794222|1039|9991|9991|SEP94D4692A27C5|Gateway_SIP_Trunk
2016/12/20 16:56:45.917|SIPT|37794222|TCP|OUT|172.20.214.10|5060|Gateway_SIP_Trunk|172.20.214.20|5060|2,100,14,1.1016^*^*|134324|93313a00-8591b72d-fa37-ad614ac@172.20.214.10|INVITE
2016/12/20 16:56:45.931|SIPT|37794222|TCP|IN|172.20.214.10|5060|Gateway_SIP_Trunk|172.20.214.20|5060|2,100,14,134.4^172.20.214.20^*|134328|93313a00-8591b72d-fa37-ad614ac@172.20.214.10|100 Trying
2016/12/20 16:56:45.932|SIPT|37794222|TCP|IN|172.20.214.10|5060|Gateway_SIP_Trunk|172.20.214.20|5060|2,100,14,134.5^172.20.214.20^*|134329|93313a00-8591b72d-fa37-ad614ac@172.20.214.10|404 Not Found
2016/12/20 16:56:45.932|SIPT|37794222|TCP|OUT|172.20.214.10|5060|Gateway_SIP_Trunk|172.20.214.20|5060|2,100,14,134.5^172.20.214.20^*|134330|93313a00-8591b72d-fa37-ad614ac@172.20.214.10|ACK
2016/12/20 16:56:45.939|SIPL|37794221|TCP|OUT|172.20.214.10|5061|SEP94D4692A27C5|172.20.214.49|50530|2,100,14,1.1018^*^*|134331|94d4692a-27c50017-705e2b41-458c0d8b@172.20.214.49|183 Session Progress
2016/12/20 16:56:46.435|SIPL|37794221|TCP|IN|172.20.214.10|5061|SEP94D4692A27C5|172.20.214.49|50530|2,100,18,41.282^172.20.214.49^*|134334|94d4692a-27c50017-705e2b41-458c0d8b@172.20.214.49|CANCEL
2016/12/20 16:56:46.436|SIPL|37794221|TCP|OUT|172.20.214.10|5061|SEP94D4692A27C5|172.20.214.49|50530|2,100,18,41.282^172.20.214.49^*|134335|94d4692a-27c50017-705e2b41-458c0d8b@172.20.214.49|200 OK
2016/12/20 16:56:46.436|CC|RELEASE|37794221|37794222|1
2016/12/20 16:56:46.436|SIPL|37794221|TCP|OUT|172.20.214.10|5061|SEP94D4692A27C5|172.20.214.49|50530|2,100,18,41.282^172.20.214.49^*|134336|94d4692a-27c50017-705e2b41-458c0d8b@172.20.214.49|487 Request Cancelled
2016/12/20 16:56:46.444|SIPL|37794221|TCP|IN|172.20.214.10|5061|SEP94D4692A27C5|172.20.214.49|50530|2,100,18,41.283^172.20.214.49^*|134337|94d4692a-27c50017-705e2b41-458c0d8b@172.20.214.49|ACK
2016/12/20 16:56:50.974|SIPL|0|TCP|IN|172.20.214.10|5061|SEP94D4692A27C5|172.20.214.49|50530|2,100,18,41.286^172.20.214.49^*|134340|94d4692a-27c50018-265abfe9-00890f87@172.20.214.49|INVITE
2016/12/20 16:56:50.975|SIPL|0|TCP|OUT|172.20.214.10|5061|SEP94D4692A27C5|172.20.214.49|50530|2,100,18,41.286^172.20.214.49^*|134341|94d4692a-27c50018-265abfe9-00890f87@172.20.214.49|100 Trying
2016/12/20 16:56:55.544|CC|SETUP|37794224|37794225|1039@SRV-CALLMANAGER-SUB|091718890|091718890
2016/12/20 16:56:55.547|CC|OFFERED|37794224|37794225|1039|091718890|091718890|SEP94D4692A27C5|Gateway_SIP_Trunk
2016/12/20 16:56:55.548|SIPT|37794225|TCP|OUT|172.20.214.10|5060|Gateway_SIP_Trunk|172.20.214.20|5060|2,100,14,1.1021^*^*|134367|99271b00-8591b737-fa3c-ad614ac@172.20.214.10|INVITE
2016/12/20 16:56:55.563|SIPT|37794225|TCP|IN|172.20.214.10|5060|Gateway_SIP_Trunk|172.20.214.20|5060|2,100,14,134.6^172.20.214.20^*|134371|99271b00-8591b737-fa3c-ad614ac@172.20.214.10|100 Trying
2016/12/20 16:56:55.563|SIPT|37794225|TCP|IN|172.20.214.10|5060|Gateway_SIP_Trunk|172.20.214.20|5060|2,100,14,134.7^172.20.214.20^*|134372|99271b00-8591b737-fa3c-ad614ac@172.20.214.10|404 Not Found
2016/12/20 16:56:55.563|SIPT|37794225|TCP|OUT|172.20.214.10|5060|Gateway_SIP_Trunk|172.20.214.20|5060|2,100,14,134.7^172.20.214.20^*|134373|99271b00-8591b737-fa3c-ad614ac@172.20.214.10|ACK
2016/12/20 16:56:55.573|SIPL|37794224|TCP|OUT|172.20.214.10|5061|SEP94D4692A27C5|172.20.214.49|50530|2,100,14,1.1023^*^*|134374|94d4692a-27c50018-265abfe9-00890f87@172.20.214.49|183 Session Progress
2016/12/20 16:56:56.941|SIPL|37794224|TCP|IN|172.20.214.10|5061|SEP94D4692A27C5|172.20.214.49|50530|2,100,18,41.300^172.20.214.49^*|134377|94d4692a-27c50018-265abfe9-00890f87@172.20.214.49|CANCEL
2016/12/20 16:56:56.942|SIPL|37794224|TCP|OUT|172.20.214.10|5061|SEP94D4692A27C5|172.20.214.49|50530|2,100,18,41.300^172.20.214.49^*|134378|94d4692a-27c50018-265abfe9-00890f87@172.20.214.49|200 OK
2016/12/20 16:56:56.943|CC|RELEASE|37794224|37794225|1
2016/12/20 16:56:56.943|SIPL|37794224|TCP|OUT|172.20.214.10|5061|SEP94D4692A27C5|172.20.214.49|50530|2,100,18,41.300^172.20.214.49^*|134379|94d4692a-27c50018-265abfe9-00890f87@172.20.214.49|487 Request Cancelled
2016/12/20 16:56:56.948|SIPL|37794224|TCP|IN|172.20.214.10|5061|SEP94D4692A27C5|172.20.214.49|50530|2,100,18,41.301^172.20.214.49^*|134380|94d4692a-27c50018-265abfe9-00890f87@172.20.214.49|ACK
Any suggestion?
12-20-2016 04:44 PM
I am assuming therefore that the above log is from the cucm, which is sending an invite, as per below, to the gateway. the gateway eventually responds with a 404 not found, which is very likely caused by missing destination patter, or your CUBE not being registered with your ISP
Can you past show sip-ua register status, and debug dial-peer when you make an outbound call through your CUBE,also add the full config.
12-21-2016 11:32 AM
This is my output:
GW-VOZ-FRISA#sh sip-ua register status
Line peer expires(sec) reg survival P-Associ-URI
This is my sip-ua running:
sip-ua
registrar ipv4:172.20.214.9 expires 3600
xfer target dial-peer
I can't see any log when I debug dialpeer, csim all, etc.
Thanks for your help.
12-21-2016 05:07 PM
If you are connected to the Router via SSH or Telnet, you may need to enable Logging (Not sure in case you already did this, but just to cover your bases).
Router# terminal monitor
Router# show log //This one will show the logging configuration
In case term mon is running and you see console messages sent to you, you should be able to get a debug from the voice gateway.
If the above is not the case, the call is not hitting the Voice Gateway and at this point the configuration on your SIP trunk could be pointing to the wrong IP
12-22-2016 07:42 AM
Attached is my Trunk configuration. It is pointing to 172.20.214.20.
I tried any kind of debug (dialpeer, voip, ccsip, ccapi, voice), but I can't see anything when I make calls. Even when I use show log, I am not able to see any log (I see logs to other matters, but not to ones I wrote).
12-20-2016 06:44 PM
Agreed with Dennis. The destination IOS sending 404 error (Not found).
You need to make sure that you are looking at the right gateway/cube which has IP 172.20.214.10. Also, make sure that you debug ccsip mess with 'terminal monitor' enabled and logging monitor is set to debugging
If you post the config of the device, then this will help.
12-21-2016 11:50 AM
My Gateway has the IP 172.20.214.20. Why CUCM is looking at 172.20.214.10 (this is my Subscriber).
Kind regards,
Heriberto
12-21-2016 02:37 PM
your trunk might be "registered" on your sub, primarily, that is why you see 172.20.214.10 as the source address.
If are sure you are looking at the correct gateway .20 and you are not seeing any SIP messages when you debug.
set up a SPAN port to that .20 and capture using wireshark the gateways input/output and filter using "sip".
if you are seeing the appropriate SIP signalling, then you should see output when you run debug ccsip messages
12-21-2016 03:20 PM
Sorry Dennis, but I don't understand very well.
My SIP trunk is stablished to 172.20.214.20 and it appears as Full Service. Is my sip-ua configuration OK?
This is my voice service voip config:
voice service voip
dtmf-interworking rtp-nte
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip handle-replaces
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
bind control source-interface GigabitEthernet0/0
bind media source-interface GigabitEthernet0/0
session transport tcp
registrar server expires max 300 min 60
early-offer forced
midcall-signaling passthru
12-21-2016 07:19 PM
your sip-ua register status should look something like this:
