CUCM Sip Trunk with Username/Password
Faisal.Saoud
Level 3
Level 3
I have been requested to integrate CUCM with Bitrix system by sip trunk, so bitrix administrator requested to create sip trunk with username and password, and also he configured on his system a sip trunk and added the user and pass of cucm in sip trunk.
How can I configure sip trunk with user and pass?
Leonardo Santana
What´s your CUCM version?
Check this link
https://supportforums.cisco.com/discussion/11835001/sip-trunk-isp-authentication-using-cisco-call-manager
Leonardo Santana
*** Rate All Helpful Responses***
System version: 12.5.1.10000-22
b.winter
There is no option in CUCM, to configure the SIP trunk with authentication credentials.
You would need to connect the CUCM to CUBE via SIP Trunk on one side, and on the other connect the CUBE with your 3rd party system, where CUBE then "registers" (using username/password) to the system.
--- Please rate this post as "Helpful" or accept as a solution, if your question has been answered ---
