CUCM SQL Query to get device profile information from CUCM 10.5
ajey_shetty
Can anyone help me with CUCM SQL Query to pull following device profile details from CUCM 10.5
Device Profile Name
Description
Extension number associated
Ajey Shetty
a.janssen
run sql select d.name as udp, d.description, n.dnorpattern as number from device as d inner join devicenumplanmap as dnpm on dnpm.fkdevice = d.pkid inner join numplan as n on dnpm.fknumplan = n.pkid and d.tkclass = 254
5 Replies 5
Hi ,
Why do you need sql? Why don't you try BAT to generate report.
You may find your answer in following thread.
https://community.cisco.com/t5/ip-telephony-and-phones/cucm-10-5-sql-to-find-user-device-profiles-set-as-logged-out/td-p/3372916
Shalid (please rate post if you find useful)
I need SQL because I am pulling that data using AXL and I am trying to automate a process to dump the DP data to our BI tool.
I checked the post you shared but did not help me much.
HARIS_HUSSAIN
Use BAT To export the PRofile Information.
*** Please rate helpful post; Mark "Accept as a Solution" if applicable
Haris
a.janssen
Working :) . Thank you so much.
