CUCM subscriber node failing authentication on IM&P servers
@Syed
Level 3
Level 3
Hello All,
Hope you are all well!
I have recently added CUCM subscriber node to the cluster and everything is working fine excepted cluster authentication between new node and IM&P servers. I get the below error on running the " show network cluster" command.
192.168.x.x CUCM04.xyz.local CUCM04.xyz.local Subscriber unknown unknown not authenticated - INITIATOR since Mon Jul 6 08:15:09 2020
Note: this is happening only on IM&P servers
I have found the problem.
Following TCP ports are allowed unidirectionally on the firewall between IM&P and CUCM and that fixed the problem
Port Direction: CUCM > IM&P
8500 TCP
5060 TCP
2555 TCP
what's the output  of "show network cluster" on CUCM publisher.
Check connectivity  between IM and Subscriber.
Response Signature
Thanks for reply.
As I mentioned CUCM network cluster status is all good.
8500 TCP
5060 TCP
2555 TCP
