07-05-2011 06:30 AM - edited 03-16-2019 05:46 AM
I have one site where some ip phones are connected with our main cucm. But rest of the phones are created at local cucme (router 2951). Is it possible that 5 phones connected with CUCM can reach to local created phones???
07-05-2011 06:41 AM
Yes, on CME configure a voip dial peer to CUCM and on CUCM configure that CME as an H323 GW.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
07-05-2011 07:00 AM
Can i configure inter cluster trunk between cucm and cucme ?
07-05-2011 07:05 AM
No, that's for CUCM CLUSTERS only.
java
07-05-2011 07:08 AM
thnaks alot. Its much appreciated if someone can give me a template/example of how CUCM and CUCME (both cucm and router having cucme can reach each other via wan connection) can be inter-connected.
07-05-2011 07:12 AM
Do i need to create separate Router pattern, Router List, Route Group and Route Partition & CSS ?
On Gateway side, what will be the voip dial peer ?
07-05-2011 07:41 AM
You can find this document as a guide to configure the CallManager:
The dial-peer in the CME should be something like this:
dial-peer voice 1 voip
destination-pattern xxxx
session target ipv4:
dtmf-relay h245-alphanumeric
voice-class codec 1
Remember to add the h323-gateway voip bind srcaddr command under the interface that has the IP address that you configured in the CallManager.
Hope it helps, please rate if it does.
- Adrian.
07-05-2011 08:14 AM
The ip phones configured on CME Router ( not on the cucm, their tftp server is itself that cme router ) can call to the ip phones configured on cucm ?
07-05-2011 08:24 AM
Yes, as long as:
1.- A dialpeer VoIP is configured in your router towards the CUCM (just like the one I put in the previous post).
2.- The CME IP address is defined as an H.323 gateway in CallManager and has a CSS assigned to reach the CallManager endpoints.
- Adrian.
02-15-2017 01:19 AM
i've configured an ICT-non gatekeeper controlled and it works !!
i don't know if there are issues with this configuration or not .
