CUCM upgradation from 8.6 to 10.0
Is it possible to upgrade cucm 8.6 directly to 10.0?
please also advice is there any type of bug in 10.0 version.
Thank you.
Jaime Valencia
Yes, review the upgrade guide for 10.0 as well as the RNs/new and changed information for all the info and changes that need to be done for the upgrade to succeed, RNs, as always, covers bugs.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Chris Deren
Ensure you review compatibility matrix as well for other integrated applications such as IMP, CCX, etc and upgrade those if needed.
Chris
