CUCM Upgradation from 8.6 to 9.1
when we upgrade cucm 8.6 to 9.1, can we use the same 9.1 iso file which we wre using for the full installation?
Thanks in Advance....
5 Replies 5
Aman Soi
Hi Joseph,
No, that is the patch u need to download from cisco site which does not have bootable.
iso used for full installation  has bootable.
regds,
aman
Manish Gogna
Hi Midhun,
You need to use an upgrade file, not the bootable file that you use for fresh installation. You can either request it through the PUT tool or you can download it from the following link
http://software.cisco.com/download/release.html?mdfid=284510097&flowid=45900&softwareid=282074295&release=9.1%282%29SU1&relind=AVAILABLE&rellifecycle=&reltype=latest
Manish
Hi Manish
thank you for your reply
i already used this file (UCSInstall_UCOS_9.1.2.10000-28.sgn.iso)  but after starting the upgrade it stck there for 6 hrs.
Then i cancelled upgrade process.
Hi Midhun,
Please ensure that you meet the hardware requirements for cucm version 9.1. If that is in place then please reboot the Publisher and attempt the upgrade again and provide the install logs if the upgrade fails.
Manish
Hi Joseph,
How many servers and IP phones u have in cluster?
regds,
aman
