CUCM upgrade from 11.0 to 11.5 SU7
Hi ,
Please help me with the CLI steps to upgrade call manager from 11.0 to 11.5 SU7
Vaijanath Sonvane
- To upgrade CUCM from version 11.0 to 11.5(x), you need to go through below upgrade guide:
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/upgrade/11_5_1/cucm_b_upgrade-guide-cucm-115.html
- All the prerequisites and upgrade tasks are mentioned in this document.
- Go through the CUCM 11.5 release notes to verify requirements, supported endpoints, limitations etc:
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/rel_notes/11_5_1/SU7/cucm_b_release-notes-cucm-imp-1151su7.html
- Go through the Cisco Collaboration Virtualization site to verify CUCM 11.5 support on VMware ESXi:
https://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/uc_system/virtualization/virtualization-cisco-unified-communications-manager.html
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
tgaur
after doing a precheck to start the upgrade from cli write :
"utils system upgrade initiate listall"
it will list the source that you can use to download the upgrade patch.
Tarun
