CUCM user unable to reset phone or apply changes
Brian Houston
I have a customer with the following issue:
Since we upgraded the CUCM from 8.6.2.21900-5 To 8.6.2.23900-10 Users cannot "reset" or "apply config" after saving changes to extension details. A popup comes back saying  "User is not authorised to perform this function"
In fact the changes are applied okay but the initial error is very misleading:
No changes were made to user roles or permissions before or after the upgrade.
Has anyone else seen this behaviour?
2 Accepted Solutions
Read this thread
https://supportforums.cisco.com/thread/2225679
Best Regards
Reset/Apply not working for CCMAdmin with custom roles
CSCug29903
Symptom:
Assigning custom roles to end/application user does not allow to use the Reset/Apply buttons
Hitting save, shows that the update was successful
Conditions:
CUCM 8.6.2.23068-1 or higher
User created Roles
Standard (Built-in) roles should work fine.
Workaround:
Add read/update privileges for the "Voice Mail Pilot web pages" resource to the custom role
Please rate all the useful posts
//Suresh Please rate all the useful posts.
Read this thread
Best Regards
CSCug29903
Symptom:
Conditions:
User created Roles
Workaround:
Brian Houston
Thanks to all who replied in relation to this bug. I applied the workaround and that resolved the problem.
