CUCM using port 5070 instead of 5060 for presence
aalejo
Level 5
Level 5
                   CUCM version 8.6.2.21900-5
Does someone have an idea why CUCM uses port 5070 for presence instead of port 5060 as in configured on the SIP trunk?
11 Replies 11
paolo bevilacqua
Probably to make it easier for the different processes to listn on different ports.
But i configured 5060 and not 5070 on the trunk . Also if i configured another port (like 5080)  it still uses 5070.
Systems wants to manage by itself
Definitly. I have two questions:
How CUCM knows to use port 5070 instead of 5060?. Unless it is hardcoded into the CUCM.
How to change the port to another port?.
To make CUCM listen on a new port you create a SIP Security Profile with a new source port - maybe check to see if someone has added one to your system?
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Everything is 5060.
And the problem is the destination port on the CUCM not the source port. Destination port is controlled on the trunk
14:35:19.602015 IP CUCM86A.38684 > CUPS86A.5070: . ack 1 win 46
If you're SIP trunk to CUPS is using port 5070 you are using or were using CUPS 6.  CUPS version 6 required the use of port 5070 because different processes were listening there that CUCM had to communicate with.  This changed with CUPS 7.0+ though so that the CUCM SIP presence trunk points to 5060.
CUPS 8.6.4.10000-28
Never use CUPS 6.x or 7.x on this expecific example. Clean installation of 8.6
aalejo wrote:
Everything is 5060.
You sound confused. From the point of view of CUCM, 'destination' port is the port you specify on the trunk.
The source port (i.e. listening port) on CUCM is configured through the SIP Trunk Security Profiles (System/Security menu).
How have you determined that CUCM is using port 5070?
Aaron
. Yes, i know. On the CUCM the destination port is configured as 5060 but wireshark shows 5070. That's exactly the issue.
Look at the trace:
CUCM86A - Cisco Unified Communications Manager 8.6 (Port 38684)
CUPS86A - Cisco Unified Presence Server 8.6 (port 5070)
Yes, i know. In this expecific example i dont care about source port only destination port. But, just in case, all incoming ports are 5060 on all profiles
Using wireshark. Take a look to the trace.
Aaron
- Alex
Hi Alex
In that case you need to widen your view of the conversation - perhaps capture from a reset of the trunk onwards.
What I imagine you will see is that an initial connection from CUCM to CUPS on port 5060 is responded to with a packet referring CUCM to port 5070 on the same server.
Aaron
