CUCM v10 phone directory with external entries
dapo100
is there any a quick and free solution based to add in the CUCM corporate directory ( not the personal directory) entries for outside phone numbers PSTN ( people that are not CUCM users) .
Dan
Deven Gandhi
End user themselves are unable to add non-corporate users to CUCM but CUCM admin can manually add them by going into "User Management" >> "End User".
5 Replies 5
Deven Gandhi
Thanks for the quick answer, will there be a limit to the number of such entries? let's say I want to add 1000 of those on top of the 1000 users that curently have phones on a BE6000M
regards
Dan
Not that I am aware of.
Hi Dan,
Please check the application described in below document if it fulfills your requirement.
https://supportforums.cisco.com/document/12735906/mars-directory-caller-details
Jaime Valencia
The only way to add entries to the built-in directory, is to have them show as users in CUCM.
Besides that, you would need to look into external directories.
java
if this helps, please rate
