05-24-2017
01:36 PM
- last edited on
03-17-2019
10:25 AM
by
NikolaIvanov
Hello everyone,
I'm trying to install the CallManager SUB v11.5 over WAN in the DR site and facing below error, is there anyone have an idea how to solve this issues.
05-24-2017 04:07 PM
By any chance does any of the passwords in that cluster contain (), [] or {}???
If they do, change the password and avoid those characters.
I'm assuming the CoW network requirements are met and that those are not an issue.
05-25-2017 12:39 AM
By any chance does any of the passwords in that cluster contain (), [] or {}??? YES for the LDAP integration
but do you think this will affect the installation of the SUB ??
05-25-2017 12:48 AM
05-25-2017 12:52 AM
Hi Jitender,
is there any way to get that log file
05-25-2017 02:06 AM
You need to configure serial port on VM for this, below is the link which you can refer for this.
https://supportforums.cisco.com/document/11936186/dumping-cucm-fresh-install-logs-virtualization
Suresh
06-12-2017 01:07 PM
Hello All
The problem has been resolved after contact Cisco TAC we found that DB user account password didn't match the application password this cos the installation issue i face
Thank you all for assistance
10-24-2017 10:07 PM
05-25-2017 02:45 AM
05-25-2017 11:10 PM
This is not the actual logs.., did you get chance to open it to read ? Seems you have not followed the procedure properly.
Suresh
05-25-2017 06:27 AM
No special characters for the security password, or any other platform user? or any of the built-in users?
05-25-2017 06:38 AM
No
01-27-2020 07:20 AM
Just want to add a point
If you are using Private IP to install it, just ping it once to make sure no one is using it in your network so if it Request timed out then only you can use it
06-07-2017 09:57 AM
We are facing the same problem, did you get any fix to this issue??
Please advise
06-07-2017 03:53 PM
Hello Yousif,
I opened a case with Cisco, still, with no luck to solve it they need more time to investigate on the log but from the troubleshooting that I have done as below:
1- Check the password of the OS make sure doesn't have special characters like () or {} as explained on the command below by
2- Check the firewall connectivity make sure there are no any blocking on any port.
for my case now Cisco TAC says the SUB server on the DR site is not able to create elm account on the PLM.
I will update you if we had any luck to solve this issue.
