08-16-2010 04:00 AM - edited 03-16-2019 12:16 AM
I need to rebuild the system, and to avoid having to get the license re-
homed I need to ensure the License MAC is the same. I have all the previous information except the details entered
for Ogranization/state/location etc. Where can I find these on the current system? I've look in lots of places but not found them yet, they must be staring at me somewhere....
Solved! Go to Solution.
08-16-2010 04:20 AM
Those details go into the SSL certs, so you can look at the cert properties on IE to see them under 'Subject' on the details tab.
Alternately you can try 'show web-security' on the server CLI.
Aaron
Please rate helpful posts..
08-16-2010 04:20 AM
Aaron
08-16-2010 05:01 AM
Aaron, Excellent thanks, that was spot on. I was also then able to pre-check it with the license tool:
