CUCM VSAT external forwarding
lkomarci
Hey everyone,
I have two phone numbers from my vsat isp provider. Outgoing calls via those two lines work well however incoming calls all go directly to one number which is wrong.
Been giving it a try but I can't figure out where I can change this number.
Any help would be much appreciated.
13 Replies 13
Leonardo Santana
Try to use voice translation rules.
https://www.cisco.com/c/en/us/support/docs/voice/call-routing-dial-plans/61083-voice-transla-rules.html
Leonardo Santana
*** Rate All Helpful Responses***
Could you  please explain  how you integrated the CUCM with your VSAT number. From the OP the call flow is not clear.
Response Signature
I wouldn't know much on where to begin with OP explanation as I'm quite a rookie in CUCM.
What I've found out for now is the gateway is ISR 4351. It has 4 FXO/FXS cards, i.e. ports with assigned DN/prefixes for VSAT lines.
Each of them has route pattern with a partition for auto registered phones assigned.
Can't/don't know how to describe it any better without sounding like a complete tool. CUCM is just one of my many tools and I rarely use it
So I assume that VSAT lines are connected to two FXO ports on ISR 4351. I think there might be Plar configured on gateway.
Could you please share the gateway Configurations.
Response Signature
  • Your gateway is configured as mgcp?
  • Do you have PLAR configured under your fxo ports?
Leonardo Santana
The gateway is configured as MGCP
  • Not sure about PLAR I'm looking into it now 
Inside the DN number config of the FXO at CUCM, do you have configured the call forward all?
Leonardo Santana
It doesn't dial 4601 as stated in attedant DN but rather 102.
I looked into PLAR on how to set it up here
https://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/212073-CUCM-PLAR-Configuration-Example.html
once I go to call routing > translation pattern I don't see any patterns there if they're necessary
There is something call Dialed  Number Analysis(DNA).
You will come to know the call flow.
Response Signature
Did you check the call forward on the DN lines of the FXO?
Leonardo Santana
so when some one calls your vsat numbers does that land on 4601?
Response Signature
lkomarci
Just a little update on my research - I realized there is no forwarding from the two external lines to this one number. The phones that have forwarding actually say forwarded on the display when there's an incoming call but not for this one.
Where or how else could this have been set up?
Check the call flow using DNA.(Dialed Number analysis)
Response Signature
