01-18-2023 09:55 PM - edited 01-18-2023 10:23 PM
My customer wants to update Microsoft windows server ,
the CUCM work with LDAP integration.
my CUCM version 11.5SU2
which LDAP support for this version of CUCM ?
01-18-2023 10:29 PM - edited 01-18-2023 10:30 PM
The following LDAP directories are supported by CUCM 11.5
Microsoft Active Directory 2019 (Minimum supported release is 11.5(1)SU7)
Microsoft Active Directory 2016
Microsoft Active Directory 2012
Microsoft Active Directory 2008 R1 (32-bit) / R2 (64-bit)
Microsoft Active Directory 2003 R1/R2 (32-bit)
Microsoft Active Directory Application Mode 2003 R1/R2 (32-bit)
Microsoft Lightweight Directory Services 2019 (Minimum supported release is 11.5(1)SU7)
Microsoft Lightweight Directory Services 2008 R1(32-bit) / R2(64-bit)
Microsoft Lightweight Directory Services 2012
Sun ONE Directory Server 7.0
Open LDAP 2.3.39
Open LDAP 2.4
Oracle Directory Server Enterprise Edition 11gR1
Other LDAPv3 Compliant Directories—Unified Communications Manager uses standard LDAPv3 for accessing the user's data. Ensure that the supportedcontrol attribute is configured in the LDAPv3 compliant directory servers to be used with DirSync. (The supportedcontrol attribute may return the pagecontrolsupport and persistentcontrolsupport sub attributes, if configured.)
01-18-2023 10:41 PM
Hi ,
the document refers to version cucm11.5 su5-su7,
but my version 11.5SU2.
any idea?
01-18-2023 11:37 PM
To which versions you are upgrading your AD server.
if its 2019, Microsoft Active Directory 2019 (Minimum supported release is 11.5(1)SU7)
01-19-2023 02:39 AM
You are correct about the doc version.
But if you would have read carefully, you would see that the table heading states "The following LDAP directories are supported by CUCM 11.5" --> Which includes every 11.5 version.
