CUCM WITH LDAP SUPPORT
iptsupport
Level 4
Level 4
My customer wants to update Microsoft windows server ,
the CUCM work with LDAP integration.
my CUCM version 11.5SU2
which LDAP support for this version of CUCM ?
Supported LDAP Directories
The following LDAP directories are supported by CUCM 11.5
  • Microsoft Active Directory 2019 (Minimum supported release is 11.5(1)SU7)
  • Microsoft Active Directory 2016
  • Microsoft Active Directory 2012
  • Microsoft Active Directory 2008 R1 (32-bit) / R2 (64-bit)
  • Microsoft Active Directory 2003 R1/R2 (32-bit)
  • Microsoft Active Directory Application Mode 2003 R1/R2 (32-bit)
  • Microsoft Lightweight Directory Services 2019 (Minimum supported release is 11.5(1)SU7)
  • Microsoft Lightweight Directory Services 2008 R1(32-bit) / R2(64-bit)
  • Microsoft Lightweight Directory Services 2012
  • Sun ONE Directory Server 7.0
  • Open LDAP 2.3.39
  • Open LDAP 2.4
  • Oracle Directory Server Enterprise Edition 11gR1
  • Other LDAPv3 Compliant Directories—Unified Communications Manager uses standard LDAPv3 for accessing the user's data. Ensure that the supportedcontrol attribute is configured in the LDAPv3 compliant directory servers to be used with DirSync. (The supportedcontrol attribute may return the pagecontrolsupport and persistentcontrolsupport sub attributes, if configured.)
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/compat/11_x/cucm_b_compatibility-matrix-cucm-imp-1151su5-su7.html
Response Signature
iptsupport
Level 4
Level 4
Hi ,
the document refers to version cucm11.5 su5-su7,
but my version 11.5SU2.
any idea?
To which versions you are upgrading your AD server.
if its 2019, Microsoft Active Directory 2019 (Minimum supported release is 11.5(1)SU7)
Response Signature
You are correct about the doc version.
But if you would have read carefully, you would see that the table heading states "The following LDAP directories are supported by CUCM 11.5" --> Which includes every 11.5 version.
