CUCMBE 7.x - Adding Device Packs and User/Phone Add
Fletcher Joyce
Guys have a client with CUCMBE 7.x and some recentley added 7945 Handsets.
I have installed the 7945 device pack as per usual and it works fine, however when I try to add a user through User Management > User/Phone Add the 7945 Phone isn't available under the Product Type drop down box.
Is there anyway to add installed devices through the User/Phone Add Method?
Fletcher
Gajanan Pande
Fletcher,
I am affraid you are hitting CSCsv42691
Workaround needs to be applied.
GP.
Pls rate helpful posts by clicking on the stars below the post !!
Gajanan Pande
Fletcher,
GP.
