CUCME 8.5 ephone dual-line & Hunt Group
dezoconnor
Level 4
Level 4
Hello Forum,
Been a whilst since I've been on here but could do with a pointer or two....
Snag experienced on site is that the first call going into the main number (200) is ringing on the reception phone which is fine, the issue arises when the second call comes in, instead of ring on the next phone in the hunt-group it rings on the second virtual line on the reception phone and then hunts.
If I remove this second line (dual-line command) from the reception phone she won’t then be able to do call transferring so kind of stuck...How do I get the call to hunt when the first line is busy?
ephone-hunt 1 sequential
pilot 200
list 221, 228, 224
final 7001
timeout 15, 15, 15
ephone-dn  1  dual-line
number 221
pickup-group 1
label Reception 221
description Reception 221
name Reception
allow watch
Darren
acampbell
Darren,
Can you try adding
number 221
pickup-group 1
label Reception 221
name Reception
allow watch
huntstop channel
Alex
Regards, Alex. Please rate useful posts.
paolo bevilacqua
huntstop channel
dezoconnor
Level 4
Level 4
Ah, as simple as that! Cheers all.
