CUE 7.0.1 Issue
wrickk_2
I have CUE 7.0.1 (NME-CUE) in a 2821. I configured the following
interface Integrated-Service-Engine1/0
ip unnumbered GigabitEthernet0/0
service-module ip address 10.32.128.23 255.255.255.0
!Application: CUE Running on NME
service-module ip default-gateway 10.32.128.11
no keepalive
ip route 10.32.128.23 255.255.255.255 Integrated-Service-Engine1/0
The problem I'm having is that I can't access the service-module IP, not even from the router... what did I miss?
13 Replies 13
What error are you getting?
no error, can't even ping 10.32.128.23 at this point.
what do you get when you issue
service-module service-engine 1/0 status?
does the interface show up/up?
Service Module is Cisco Integrated-Service-Engine1/0
Service Module supports session via TTY line 66
Service Module is in Steady state
Service Module heartbeat-reset is enabled
Getting status from the Service Module, please wait..
Cisco Unity Express 7.0.1
CUE Running on NME
Does the please wait ever go away? Also Im assuming you did a shut/no shut on the interface already. You may want to try reseating the NME-CUE.
"please wait" never changes. I tried shut/no shut several times. I re-seated the card and still nothing. I may just open a TAC case, thanks for your help.
Were you ever able to get this working? I'm running into the exact same situation.
--Brandon
marevaloc
I have the same problem.
How do you resolv this issue?
tks
Wrong config.
Send it.
This is my config,
I can't ping 10.247.93.153
help me please!!!
tks
  interface GigabitEthernet0/0
  description Lan
  ip address 10.247.93.150 255.255.254.0
  ip helper-address 10.247.98.219
  ip helper-address 10.247.100.1
  duplex auto
  speed auto
  media-type rj45
  h323-gateway voip interface
  h323-gateway voip bind srcaddr 10.247.93.150
interface Integrated-Service-Engine2/0
  service-module ip address 10.247.93.153 255.255.254.0
  service-module ip default-gateway 10.247.93.150
  no keepalive
You do not have the host route for the module.
Hi Guys..
You need to add the static route for the Service Engine module. For example Service Engine Module IP address is 10.68.90.4 you need to add below static IP address.
Router(config)#  ip route 10.68.90.4 255.255.255.255 Integrated-Service-Engine1/0
Note:Please see the mask in the route..
Vaijanath
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
Tks all.
I add the static route, and ping succesfull.
But the browser with ip address of "CUE" don't response.
Any idea?
