12-14-2009 11:37 PM - edited 03-18-2019 10:55 AM
I have configured the CUEAC server and below are the details of it:
CUEAC Administration Version: 3.1.1.133
CUEAC Console Version: 3.1.1.511
When we get a call on the console, it rings only once instead of continuously ringing, even if the call is on the queue and not answered.(The problem is Intermmitent, sometimes if we close and login again it rings continuously for the first time, then again the same problem continues)
Tried checking with other systems also, the problem remains the same.
I tried doing the Ring settings on the Console ->Preferences, but still no progress.
Pls. suggest if anything more needs to be done.
rgds,
Gifton
Solved! Go to Solution.
03-30-2010 11:43 AM
Hi Marcus,
It sounds like this bug
CSCtc84599 Bug Details | Bug #1 of 2 | < Previous | Next > |
Operator console rings only once for incoming calls | |
Symptom: Operator console rings only once for incoming calls Conditions: After upgrading to CUBAC 3.1.1.5, only the first call to the operator console will ring through the speakers until the operator picks up. All subsequent calls will ring through the speakers only once although the call still shows as being in queue. Call handling is still working, but when you have more agents the other agents may not realize that there is calls waiting in queue. Restarting the client console will allow the first call to work as above, but all subsequent calls will fail, so not really feasable as a workaround. Workaround: None Further Information The above issue is also seen in CUEAC 3.1.1.5. | Status Fixed Severity 1 - catastrophic Last Modified In Last 3 Days Product Cisco Unified Attendant Consoles Technology 1st Found-In 3.1(1.5) Fixed-In Release-Pending |
Hope this helps!
Rob
Please support CSC Helps Haiti
03-26-2010 05:31 AM
I have the same issue, did you find a solution?
Marcus
03-30-2010 11:43 AM
Hi Marcus,
Hope this helps!
Rob
02-14-2012 12:22 PM
This was indeed a bug, it has now been fixed.
