03-02-2008 07:30 AM - edited 03-15-2019 09:10 AM
I have configured the CUPS and when I go to the troubleshooter its all green for the integration and I did the LDAP integration and followed the three documents: Installation, Administration & Deployment Guide, but now when I try to login with the CUPC, it gives me this error: Unknown Login Failure
What is the problem? and how to solve it ASAP.
Fady
03-03-2008 07:45 AM
Hi Fady,
Are you users in AD? If so do you have them sitting under a hierarchical structure (i.e. multiple OUs)? We had to change the LDAP integration port to be the Global Catalog server port (3268) because the GC supports wider LDAP searches.
Ken.
03-04-2008 08:09 AM
I tried this one but still I am not able to login form the CUPC. :/
even though all the result of the troubleshooter is correct.
I hope I get an answer on this.
Fady
03-04-2008 04:04 PM
Fady, i am having the same exact issue! I have followed the guides but the cupc health shows invalid cerdentials
03-05-2008 12:05 AM
You've probably done this already, but just to check: are your users enabled for the use of UPS and UPC in your CUCM?
Can you find them in the CUPS-webpage under System --> Status?
Have you configured them under Application --> Cisco Unified Personal Communicator --> User Settings?
Angelique
03-05-2008 07:00 AM
I have tested all these, it is all fine but still can not connect using the CUPC. :/
03-06-2008 07:30 AM
Ok fady, this worked for me: Frist check if to make sure this is not your problem:
This was broke for me. After i fixed this The CUPSC still would not connect so I went over to check my incoming ACL. I was using wild cards like this *.*.*.* to accept all connections. I was told that I should change it to just the word ALL in all caps then BANG! it worked! Good luck
03-05-2008 02:48 PM
I have the same issue with a new CUPS installation (I already installed 2 other ones). In the CUPC problem report, I can see that the CUPC can't connect to SOAP server. however, connectivity is OK, and troubleshooter also.
still no solution
07-31-2008 01:06 AM
Hi jcani,
I have had the same problem (2 previous CUPS installations succesful), but for a new one the SOAP server connect error in the CUPC report.
Troubleshooter and connectivity ok. In my case, I noticed the an error in the RTMT: ClusterManagerAlarmCatalog, Name CLM_UnrecognizedHost. The problem was a misspelling in the Publisher hostname (CCM1 instead of CM1) during the CUPS installation (but the installation process do not show any error!!!).
So, I installed the CUPS again with the right Publisher hostname and the SOAP issue was fixed automatically.
I hope it helps,
Francesc
05-28-2009 01:55 PM
Hi every body,
I have the same error message. I did all mentined steps. Including the reinstall, but the status is the same.
Have you any other tip to apply an solve this mattter.
