Custom Ringtone for 3905 model
jaheshkhan
Level 4
Level 4
May I know how to upload custom ringtone for 3905 Model phones? is it supporting it from Ringlist.xml? I cannot see the ringtone mentioned in ringlist.xml. We would like to add our own ringtone to 3905 model...
7 Replies 7
jaheshkhan
Level 4
Level 4
Any help in this regard? custom ringtone possible with 3905 model or not? or any other ways to add custom ringtone to these models?
I am facing the same issue, can anyone suggest 3905 support custom ringtone files.
Is this affecting all your phone models or just 3905?
I suggest you to backup your current ringlist.xml through cli command file get tftp Rilglist.xml, then delete from tftp list, in the OS Admin page the following files:
Ringlist.xml
Ringlist-wb.xml
RingList.DAT
Ringlist-wb.xml.sgn
Ringlist.xml.sgn
After that upload your custom Ringlist.xml and restart the TFTP service.
All files other than Ringlist.xml will be recreated after the TFTP service has been restarted.
Carlo
Please rate all helpful posts "The more you help the more you learn"
I did the above activity on a subscriber node, but after restart no files are regenerated. Please suggest.
Please let me know  which version of CUCM are you running.
In the meanwhile..
Add the following line to a new file and name it Ringlist-wb.xml. Upload it to the CUCM TFTP / Dir and restart TFTP Service.
<CiscoIPPhoneRingList>
<Ring>
<DisplayName>Ascent</DisplayName>
<FileName>Ascent.rwb</FileName>
</Ring>
<Ring>
<DisplayName>Calculation</DisplayName>
<FileName>Calculation.rwb</FileName>
</Ring>
<Ring>
<DisplayName>Delight</DisplayName>
<FileName>Delight.rwb</FileName>
</Ring>
<Ring>
<DisplayName>Evolve</DisplayName>
<FileName>Evolve.rwb</FileName>
</Ring>
<Ring>
<DisplayName>Mellow</DisplayName>
<FileName>Mellow.rwb</FileName>
</Ring>
<Ring>
<DisplayName>Mischief</DisplayName>
<FileName>Mischief.rwb</FileName>
</Ring>
<Ring>
<DisplayName>Playful</DisplayName>
<FileName>Playful.rwb</FileName>
</Ring>
<Ring>
<DisplayName>Reflections</DisplayName>
<FileName>Reflections.rwb</FileName>
</Ring>
<Ring>
<DisplayName>Ringer</DisplayName>
<FileName>Ringer.rwb</FileName>
</Ring>
<Ring>
<DisplayName>Ripples</DisplayName>
<FileName>Ripples.rwb</FileName>
</Ring>
<Ring>
<DisplayName>Vibes</DisplayName>
<FileName>Vibes.rwb</FileName>
</Ring>
</CiscoIPPhoneRingList>
Please let me know
Carlo
cucm version : 12.5 SU5
