Database restore when upgrading cucm 6.x or 7.x to 8.x
feisalb
Hello All
If I backup my database in 6.x or 7.x version of cucm and then upgrade to 8.x, to get it up and running can I simply restore the older version database onto 8.x?
Taking into account the upgrade matrix and licensing have been adhered to.
Feisal
Rob Huffman
Hi Feisal,
The DRF backup/restore must be on the exact same version (including SR's)
so this will be a two step process.
Here's a clip;
Caution
Before you restore Cisco Unified Communications Manager, ensure that the Cisco Unified Communications Manager version that is installed on the server matches the version of the backup file that you want to restore.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/drs/6_0_1/drs/drsag601.html#wp169048
Cheers!
Rob
Finally I have got Rob to answer one of my many questions that I have posted, it is an honour sir.
From you answer I assume that if I upgrade software levels the database is upgraded as part of the process.
If the upgrade fails for whatever reason I can activate the original cucm version. And in a db failure of the current version I can use the backup to restore.
Feisal
Rob Huffman
Hi Feisal,
I'm honored by your kind words my friend, it's a pleasure
When you upgrade along the supported incremental path the db is upgraded
appropriately along the way as well. If for some reason the upgrade fails you
can rollback to the original version which is sitting on the inactive partition. You
will need to restart/restore the database replication if you do a version rollback
but it is certainly possible. If you were doing the 6.x to 7.x to 8.x path, you might want to
do this as separate upgrades where you move 6.x to 7.x let everything simmer down
do new DRS backups etc. and then move to 8.x in a separate window. There are many
many considerations like hardware, licensing, phone firmware etc. etc. so spending as
much time planning and doing due diligence as possible is always a great idea.
Cheers!
Rob
So what happens when you are at 6.3 and lose a node in a cluster.  If there are only install disks for 6.0, you can't build another 6.0 node and then upgrade because the databases are at a different version?
