05-11-2015 03:03 AM - edited 03-17-2019 02:57 AM
What type of database & which version is used in
CUCM - System version:9.1.1.20000-5.
CCX – System Version:9.0.2.10000-71
Thanks & Regards,
M.Mohamed Raffiudeen...
Solved! Go to Solution.
05-11-2015 05:51 AM
For UCCX 9.0.2 , Informix IDS 11.50.UC9X7
http://docwiki.cisco.com/wiki/Unified_CCX_Software_Compatibility_Matrix_for_9.0%282%29
Manish
05-11-2015 04:05 AM
CUCM uses an Informix database - but you can't get direct access to it. You have to go via the CUCM APIs.
GTG
05-11-2015 04:29 AM
Thanks for the answer, is there a specific version of the DB type.
Thanks & Regards,
05-11-2015 05:51 AM
Manish
