12-04-2012 11:05 PM - edited 03-16-2019 02:33 PM
Dear All,
Am using CME 8.6 connected with E1 to the pstn.
How i can configure the the first 5 channels for recieving only calls directly to the receptionist or the auto-attendent (plar opx), and the rest of the channels in a trunk group for out going calls added to the dial-peer??????
For the receiving only calls channels trunk group is also used?????????????
thanks
12-04-2012 11:40 PM
Hi Mohammed,
Configure the inbound and outbound dial-peers and assing the trunk groups accordingly let me know how it goes...
controller E1 0/0/0
pri-group timeslots 1-31
trunk-group Incoming timeslots 1-5
trunk-group Outgoing timeslots 6-31
Najaf
12-05-2012 10:10 PM
thanks Najaf for your replay, is there a resource guide for configuing controller E1?
12-06-2012 09:10 PM
Hi Mohammed,
Hope below URL will help with regards to configuration of E1.
http://www.cisco.com/en/US/docs/wireless/asr_901/Configuration/Guide/t1e1.pdf
Najaf
Please rate when applicable or helpful !!!
12-05-2012 02:22 AM
That happens already automatically. You do not need to do anything.
12-05-2012 10:13 PM
Thanks Paolo,
can u explain how it happens automatically.? i want it to be as a trunk group , if the first channel is busy go the next channel , but i want only 5 ch for incoming..
12-06-2012 02:51 AM
You cannot control how many calls telco will send to to.
If you want only 5 incomong calls, you have to ask telco, not configure trunkgroup.
