deference between CP-8831-DC-EU-K9= and CP-8831-EU-K9= psychically
Nawaf
Hi,..
what is the deference  between CP-8831-DC-EU-K9= and CP-8831-EU-K9= psychically
and can i use CP-8831-DCU-S= with  the CP-8831-DC-EU-K9= as a stand alone solution
regards
HARIS_HUSSAIN
1) CP-8831-EU-K9=
Cisco Unified IP Conference Phone 8831 base and control panel for APAC, EMEA, and Australia
2) Optional Cisco Unified IP Conference Phone 8831 Daisy Chain Kit for APAC, EMEA, and Australia. Kit contains:
● Cisco Unified IP Conference Phone 8831 Base Unit
● Daisy Chain Cable (18 ft, 5.5 m)
So this Daisy Chain Kit do not have the control Panel Unit. If you have extra control Panel Unit you can use them as standalone.
George Sotiropoulos
 CP-8831-EU-K9=   This is the Actual Phone: Cisco Unified IP Conference Phone 8831 base and control panel for APAC, EMEA, and Australia
CP-8831-DC-EU-K9=  This is Optional Daisy Chain Kit
CP-8831-DCU-S= This is the SPARE control which has nothing to do with the daisy chain kit (which yes you can use it) but there is no reason to purchase it, instead of purchasing the CP-8831-EU-K9.
You may always check the following link:
Hope this helps,
George
Hope the above helps,
gsotirop
HARIS_HUSSAIN
1) CP-8831-EU-K9=
this is what i want to know....thank you
Yes, this is correct
gsotirop
