delay in connecting call
SJ SJ
i am facing delay in dialing calls from Cisco CP3905 registered on CME. It takes around 10 seconds to connect the call. How to reduce this time in Cisco CME with SIP phone 3905 registered to it.
Manish Gogna
can you add the following under voice register pool for 3905 and test again
digit collect kpml
Manish
this command is not available.
IOS Version c3845-adventerprisek9-mz.151-4.M10.bin
Yelbanz
Hi, Same problem encountered. May i know what is the resolution made to resolve this issue.
My first guess would be that you are encountering the interdigit timeout.
Suggestion: Start a new post describing your problem. Post a copy of your CME config and dial-peers (or better yet the entire config on the router...sanitized of course). That will get more attention than commenting on an old post.
Maren
