Deleting CUCM 9.1 Expired CAPF Cert
Ayodeji Okanlawon
Gents,
I did a change today to delete expired CAPF cert on our CUCM 9.1 cluster. After deleting the cert, phones restarted. Is this normal? IS there any documentation that supports this behaviour
Please rate all useful posts
Deepak Rawat
Hi Ayodeji,
Please find the defect below filed for this behavior:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCut58407/?referring_site=bugquickviewredir
Deepak
Vaijanath Sonvane
Hi Ayodeji,
Phone restart seems to be normal after deleting expired CAPF certificate. Please see section "Remove and Regenerate Certificates in CUCM" in below URL:
https://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/200199-CUCM-Certificate-Regeneration-Renewal-Pr.html#anc16
I hope this is helpful to you.
Vaijanath Sonvane
(Please rate if this is helpful)
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
Deepak Rawat
Hi Ayodeji,
Deepak
Thank you Deepak! You are a life saver :)
Thanks for your kind words Ayodeji :) glad that I was able to help.
Deepak
