Deleting Ephones and Ephones-dn
techguy
Level 4
Level 4
I have a h323 gateway with SRST enabled. All the ephones on gateway are added durung srst (i didn't add manually). Since, i have changed many phones and assigned to different users. Now during SRST, many user gets different cme extension due to exchange of many phones. Now i want to delete all ephones related information from gateway so that next time SRST occurs,it would download again all ephone information from CUCM.
Thanks.
11 Replies 11
j.huizinga
Level 6
Level 6
SRST doesn't add ephone's and ephone-dn configuration.
You maght have CME in SRST fallback mode, and then there are several options.
I normally choose the one that acts as classic SRST, no adding of ephone's.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmesrst.html
Bye,
JH
I never added epohnes in cme since i am using below commands.
telephony-service
srst mode auto-provision all
srst ephone template 1
srst dn template 1
srst dn line-mode dual
Question is how to delte the ephones and ephones-dn. Thanks
Hi.
Please post your  entire vg config so we can look better at your issue
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
Just remove the ephone and ephone-dn
Like:
no ephone X
no ephone-dn X
Bye,
Jan
I have around 150 ephones. Cant delete one by one
When  I have a config which is to messy, I take the whole configuration in notepad.
Remove what I don't want, then do a erase nvram, reboot and apply the configuration.
You might try no telephoney service, maybe this will remove the ephone's and then apply again telephony service
Bye,
Jan
i think you have to use a method which will not allow your ephone on your configuration , so please use one of the belwo
1-under telephony-service (srst mode auto-provision none).none—Does not include information for learned ephones or learned ephone-dns in the running configuration. Use this keyword when you want Cisco Unified CME to provide SRST fallback services for Cisco Unified Communications Manager.
or
2-usef call-manager-fallback will do the same.
call-manager-fallback  instead of telephony-service
all phones will resgisters for SRST and you won't sees any ephone or ephone-dn on your running-config. You can use "show ephone registered"  to check that all phones registered correctly.
Thank you
please rate all useful information
dinesh.purohit
U hav to give no telephony- services
no ephone x
no ephone -dn all
Jason Lee
In your case you are actually using SRST in CME mode.  The Telephony-Service command invokes SCCP CME on the router.  No biggie there.  The auto-provision-none command provided earlier in the feed will work.  If you prefer to minimize configuration on the router, you might consider switching to traditional SRST using the call-manager-fallback.
Here is a configuration guide to help out.
R2#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
R2(config)#no tel
R2(config)#no telephony-service
Reset-All: clean up DN 6 chan 1 (1237)
Reset-All: clean up DN 6 chan 2 (1237)
Reset-All: clean up DN 6 chan 3 (1237)
Reset-All: clean up DN 6 chan 4 (1237)
Reset-All: clean up DN 6 chan 5 (1237)
Reset-All: clean up DN 6 chan 6 (1237)
Reset-All: clean up DN 6 chan 7 (1237)
Reset-All: Sync DN 6 chan 8 (1237) and htsp
All DNs in DOWN state
Skinny Deleted entries for 3 phones
kevinpython
Same problem for me.
Clear statistics or deactivate call-manager-fallback and reactivate it does not clear the logs.
Is there really no other option than rebooting the gateway ?
