03-08-2013 05:27 AM - last edited on 03-25-2019 08:21 PM by ciscomoderator
I have installed a CUCM subscriber on a MCS 7825 using CUCM 8.5.1.10000-26
The system works as expected, but at the boot it stops giving the error in subject, and I need to press continue to make the system boots. When booted everything works as expected...
Any help will be greatly appreciated, thanks in advance
Gianstefano Monni
03-08-2013 06:05 AM
Hi Monni,
What is the error u get while booting? Secondly, what is the exact hardware .
Please also check the hardware compatibility matrix for MCS servers.
regds,
aman
03-08-2013 08:15 AM
HI,
Thanks for your answer. According to the list, the CUCM 8.5.1 seems to be supported on MCS 7825. Rite now I'm only able to connect on VPN, do you know what log file I should check to see the exact error message?
gianstefano
