11-06-2007 02:57 PM - edited 03-15-2019 07:05 AM
What would be the correct device pack that includes the phone types 7906 and 7911?
The 7905s are no longer available. The 7906 seems to be the replacement model.
The Device Package release 4.0(46.4) only includes the 7911.
Any info?
Solved! Go to Solution.
11-06-2007 03:55 PM
Hi Fureya,
I'm sorry to say the 7906 is not supported in CCM 4.0(2). Here are some references;
Q. What Cisco Unified Communications Manager release is required for the Cisco Unified IP Phone 7906G?
A. Customers are required to use the most recent version of each Cisco Unified Communications Manager for full support: Cisco Unified CallManager Version 3.3(5)SR2, 4.1(3)SR3a, or 4.1(2)SR1 for Skinny Client Control Protocol (SCCP) only; Cisco Unified Communications Manager Versions 5.0(2) and higher for both SCCP and Session Initiation Protocol (SIP) support.
http://www.cisco.com/en/US/products/hw/phones/ps379/products_qanda_item0900aecd8048f829.shtml
Supported in Cisco Unified CallManager Versions 3.3(5)SR2, 4.1(3)SR3a, 4.2(1)SR1, and higher using Skinny Client Control Protocol (SCCP); supports both SCCP and Session Initiation Protocol (SIP) with Cisco Unified CallManager Version 5.0(2)
http://www.cisco.com/en/US/products/hw/phones/ps379/products_data_sheet0900aecd8048f738.html
Hope this helps! Sorry for the bad news, perhaps the 7911 is a better choice anyways :)
Rob
Please remember to rate helpful posts.....
11-06-2007 03:55 PM
Hi Fureya,
Rob
11-07-2007 06:45 AM
Thank you for info.
We use 7905s as the wall-phones where we need only one port for network connectivity. We thought that 7906 would be the basic replacement model.
I guess we will have to go with the 7911s until we upgrade our cluster and not be limited with the available hardware options.
Thanks again.
11-07-2007 07:42 AM
Hi Fureya,
You are most welcome :) It's too bad the 7906 is not supported as you say but the 7911 should Wall Mount quite nicely. Be sure to disable the Network port if the phone is in an open area.
Take care,
Rob
11-07-2007 12:25 PM
Thanks again.
