Dial Peer Counter SNMP Monitoring
ratlansk
Greetings,
I am trying to find a way to monitor some of the counters returned by the show dial-peer voice command on our VoIP gateways. Specifically, I've been trying to find SNMP objects for the following counters:
     Successful Calls = 535957, Failed Calls = 48671, Incomplete Calls = 1350
        Accepted Calls = 0, Refused Calls = 0,
The dial peers are a mixture of pots and voip. We incur failed and incomplete calls, and I want to find a way to get the data and graph it.
I've not had any luck finding any relevant MIBs or other documentation. Has anyone done this, or monitored these stats in a different way?
Rick
jirochaguerra
I found a lot of information but nothing like that!
Because, "show dial-peer voice summary" command, shows admin and op status, but It's everything alright with or without connectivity therefore It's not useful
I hope somebody else can help us!
https://www.cisco.com/c/en/us/support/docs/ip/simple-network-management-protocol-snmp/63607-mib-voip-show.html#s3
https://www.circitor.fr/Mibs/Html/C/CISCO-VOICE-DIAL-CONTROL-MIB.php
jirochaguerra
I got it!
Try with this table! 1.3.6.1.2.1.10.21.1.2.2
And then, you must use "show snmp mib ifmib ifindex" command for find your interface!
ucanduc
Level 4
Level 4
I had to retrieve the dial-peer operational status monitored with SIP Options and I could retrieve it through 1.3.6.1.2.1.2.2.1.8 ifOperStatus
When the dial-peer is up, the result is 1.
When the dial-peer is Busied Out, the result is 3
