Dial Peer for 911 question
joeharb
Level 5
Level 5
I have a question regarding the setup of an off site branch...The branch has 2 pots lines coming into it and we would like use the pots line for toll free and local calls as well as 911...is there a way to give the 911 dialpeer precedence globaly so they would disconnect an existing call and complete the 911 call...
Joe
paolo bevilacqua
No, ASAIK the router will not disconnect calls to make room for emergency call.
Agreed.
Another possible solution..
If only using 1 dial-peer for toll free, and other dial-peers for 911.
A possibility would be to always keep 1 of your POTS lines open. Use the max-conn 1 statement on your toll free dp.
Please rate helpful posts.
Jeff
