Dial Peer Issues
ndegwajim
Hey folks,
I'm having an issue sending out calls from the CCME router. I can't receive calls either though i can hear the line ring when i call it. All phones re registered and have directory numbers assigned
FXO configs
voice-port 0/1/0
connection plar 5300
caller-id enable
voice-port 0/1/1
connection plar 5301
caller-id enable
Dial- Peer configs
dial-peer voice 1 pots
destination-pattern ...............
port 0/1/0
prefix 9,
dial-peer voice 2 pots
destination-pattern 9...............
port 0/1/1
prefix 9,
dial-peer voice 3 voip
destination-pattern 5330
session protocol sipv2
session target ipv4:192.168.200.4
dtmf-relay sip-notify
codec g711ulaw
no vad
telephony-service
no auto-reg-ephone
load 7960-7940 P00307020400
load 7975 SCCP75.8-5-4S
load 7936 cmterm_7936.3-3-9-0
max-ephones 30
max-dn 50
ip source-address 192.168.200.1 port 2000
voicemail 5330
max-conferences 4 gain -6
transfer-system full-consult
secondary-dialtone 9
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn  1  dual-line
number 5300
name RECEPTION
call-forward busy 5330
call-forward noan 5330 timeout 10
ephone-dn  2  dual-line
number 5301
name RECEPTION
12 Replies 12
david-lima
Level 4
Level 4
Hi friend, try changing the
port  0/1/1
prefix 9,
with this one
destination-pattern 9T
port  0/1/1
hth
David
Thanks. I'll test and advice tomorrow
paolo bevilacqua
Test these lines with a regular telephone.
i tested the line with an analog handset and line works fine
1 Is your phone ringing when you run "csim start 5300"?
2 Try to use "plar opx" instead of "plar".
Can you post "sh voice port *" output?
Router may be getting a battery reversal. To confirm, enable "debug vpm signal" with "term mon" when receiving or making a call.
Do not enable any other debug and do not use attachment when reporting results.
output from the debug command. Please note that i'm getting a single ring followed by a busy signal. Thanks in advance
CCME#debug vpm signal
Voice Port Module signaling debugging is enabled
CCME#term mon
CCME#
*Mar  3 11:11:48.922: htsp_process_event: [0/3/0, FXOLS_ONHOOK, E_DSP_SIG_0000]fxols_onhook_ringing
*Mar  3 11:11:48.922: htsp_timer - 125 msec
*Mar  3 11:11:49.050: htsp_process_event: [0/3/0, FXOLS_WAIT_RING_MIN, E_HTSP_EVENT_TIMER]fxols_wait_ring_min_timer
*Mar  3 11:11:49.050: htsp_timer - 10000 msec
*Mar  3 11:11:49.970: htsp_process_event: [0/3/0, FXOLS_RINGING, E_DSP_SIG_0100]
*Mar  3 11:11:49.970: fxols_ringing_not
*Mar  3 11:11:49.970: htsp_timer_stop
*Mar  3 11:11:49.970: htsp_timer_stop3 htsp_setup_ind
*Mar  3 11:11:49.970: [0/3/0] get_local_station_id calling num= calling name= calling time=03/03 11:11  orig called=
*Mar  3 11:11:49.970: //-1/xxxxxxxxxxxx/VTSP:(0/3/0):-1:-1:-1/vtsp_allocate_cdb:
   CDB=0x67B2D700
*Mar  3 11:11:49.970: //-1/xxxxxxxxxxxx/VTSP:(0/3/0):-1:-1:-1/vtsp_do_call_setup_ind:
   Event=E_TSP_SETUP_IND
   Progress Indication=3, CarrierIDCode=, Info Trans Capability=144, Source Carrier ID=, tg_label_flag=0
*Mar  3 11:11:49.970: //-1/661729658250/VTSP:(0/3/0):-1:-1:-1/vtsp_do_normal_call_setup_ind:
*Mar  3 11:11:49.974: //-1/661729658250/VTSP:(0/3/0):-1:-1:-1/vtsp_timer:
   Timer Start Time=19112499, Timer Value=180000(ms)
*Mar  3 11:11:49.974: //-1/661729658250/VTSP:(0/3/0):-1:-1:-1/vtsp_do_normal_call_setup_ind:
   IC State Machine (ICSM) Added
*Mar  3 11:11:49.974: //-1/661729658250/VTSP:(0/3/0):-1:-1:-1/vtsp_insert_cdb:
*Mar  3 11:11:49.974: //-1/661729658250/VTSP:(0/3/0):-1:1:1/vtsp_dsm_opened_cb:
*Mar  3 11:11:49.974: //-1/661729658250/VTSP:(0/3/0):-1:1:1/vtsp_process_event:
   [state:S_SETUP_IND_PEND, event:E_VTSP_DSM_OPEN_SUCCESS]
*Mar  3 11:11:49.974: //-1/661729658250/VTSP:(0/3/0):-1:1:1/act_setup_ind_pend_success:
*Mar  3 11:11:49.974: //-1/661729658250/VTSP:(0/3/0):-1:1:1/vtsp_realloc_cdb:
   CDB=0x67B2D700
*Mar  3 11:11:49.974: //-1/661729658250/VTSP:(0/3/0):-1:1:1/vtsp_indicate_call:
*Mar  3 11:11:49.974: //-1/661729658250/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=0   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
*Mar  3 11:11:49.974: //-1/661729658250/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x672AE66C, Call Info(
   Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
   Incoming Dial-peer=0, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
*Mar  3 11:11:49.978: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Mar  3 11:11:49.978: :cc_get_feature_vsa malloc success
*Mar  3 11:11:49.978:  cc_get_feature_vsa count is 1
*Mar  3 11:11:49.978: :FEATURE_VSA attributes are: feature_name:0,feature_time:1730644512,feature_id:166
*Mar  3 11:11:49.978: //166/661729658250/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown))
*Mar  3 11:11:49.978: //166/661729658250/VTSP:(0/3/0):-1:1:1/vtsp_insert_cdb:
*Mar  3 11:11:49.978: //166/661729658250/VTSP:(0/3/0):-1:1:1/vtsp_timer:
*Mar  3 11:11:49.978: //166/661729658250/CCAPI/cc_process_call_setup_ind:
   Event=0x67286D38
*Mar  3 11:11:49.982: //166/661729658250/CCAPI/ccCallSetContext:
   Context=0x686DC218
*Mar  3 11:11:49.982: //166/661729658250/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 166 with tag 0 to app "_ManagedAppProcess_Default"
*Mar  3 11:11:49.982: //166/661729658250/CCAPI/ccCallSetupAck:
   Call Id=166
*Mar  3 11:11:49.982: //166/661729658250/CCAPI/cc_api_set_transfer_info:
   Transfer Number=, Transfer Reason=0x0
*Mar  3 11:11:49.982: //166/661729658250/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=TRUE, Tone=Dial Tone,
   Tone Direction=Network, Params=0x0, Call Id=166
*Mar  3 11:11:49.986: //166/661729658250/CCAPI/ccSetDigitTimeouts:
   Initial Digit Timeout=-1000(ms), Inter Digit Timeout=-1000(ms)
   Call Entry(Inter Digit Timeout=10000(ms), Initial Digit Timeout=10000(ms))
*Mar  3 11:11:49.986: //166/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
   (callID=0xA6, digit_event=0x1, enable=TRUE, consume=FALSE)
*Mar  3 11:11:49.986: //166/661729658250/CCAPI/ccCallReportDigits:
   Enabled=TRUE, Call Id=166
*Mar  3 11:11:49.986: //166/661729658250/VTSP:(0/3/0):-1:1:1/vtsp_report_digit_control:
*Mar  3 11:11:49.986: //166/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x672AE66C, callID=0xA6, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
*Mar  3 11:11:49.986: //166/661729658250/CCAPI/cc_api_call_report_digits_done:
   Enabled=TRUE, Disposition=0x0, Interface=0x672AE66C, Call Id=166
   Call Entry(Initial Digit Timeout=10000(ms), Inter Digit Timeout=10000(ms))
   Digit Reporting=TRUE
*Mar  3 11:11:49.986: //166/661729658250/VTSP:(0/3/0):-1:1:1/vtsp_process_event:
   [state:S_SETUP_INDICATED, event:E_CC_SETUP_ACK]
*Mar  3 11:11:49.986: //166/661729658250/VTSP:(0/3/0):-1:1:1/act_setup_ind_ack:
   Fax Relay=TRUE, Dial Tone=TRUE, Digit Collect=TRUE, Overlap=FALSE, DID=FALSE
*Mar  3 11:11:49.986: //166/661729658250/VTSP:(0/3/0):-1:1:1/vtsp_timer_stop:
   Timer Stop Time=19112500
*Mar  3 11:11:49.990: htsp_process_event: [0/3/0, FXOLS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]
*Mar  3 11:11:49.990: fxols_wait_setup_ack:
*Mar  3 11:11:49.990: [0/3/0] set signal state = 0xC timestamp = 0fxols_check_auto_call
*Mar  3 11:11:50.262: htsp_process_event: [0/3/0, FXOLS_PROCEEDING, E_DSP_SIG_0110]fxols_rvs_battery
*Mar  3 11:11:50.262: htsp_timer_stop2
*Mar  3 11:11:59.986: //166/661729658250/CCAPI/cc_handle_inter_digit_timer:
   Generate inter-digit timeout CC_EV_CALL_DIGIT_END event
*Mar  3 11:11:59.986: //166/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
   (callID=0xA6, digit_event=0x0, enable=FALSE, consume=FALSE)
*Mar  3 11:11:59.986: //166/661729658250/CCAPI/ccCallReportDigits:
*Mar  3 11:11:59.986: //166/661729658250/VTSP:(0/3/0):-1:1:1/vtsp_report_digit_control:
*Mar  3 11:11:59.986: //166/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x672AE66C, callID=0xA6, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
*Mar  3 11:11:59.986: //166/661729658250/CCAPI/cc_api_call_report_digits_done:
   Digit Reporting=FALSE
*Mar  3 11:11:59.986: //166/661729658250/CCAPI/ccCallDisconnect:
   Cause Value=28, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=28, Call Entry(Responsed=TRUE, Cause Value=28)
*Mar  3 11:11:59.986: //166/661729658250/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
*Mar  3 11:11:59.986: //166/661729658250/VTSP:(0/3/0):-1:1:1/vtsp_process_event:
   [state:S_DIGIT_COLLECT, event:E_CC_DISCONNECT]
*Mar  3 11:11:59.990: //166/661729658250/VTSP:(0/3/0):-1:1:1/act_pre_con_disconnect:
   Cause Value=28, Hairpin=FALSE
*Mar  3 11:11:59.990: //166/661729658250/VTSP:(0/3/0):-1:1:1/vtsp_timer_stop:
   Timer Stop Time=19113500
*Mar  3 11:11:59.990: //166/661729658250/VTSP:(0/3/0):-1:1:1/vtsp_ring_noan_timer_stop:
   [Number Unobtainable]-Tone Played In Direction [Network]
*Mar  3 11:11:59.990: //166/661729658250/CCAPI/cc_api_call_disc_cause_update:
   Cause Value=16
   Call Entry(Disconnect Cause=16)
*Mar  3 11:11:59.990: //166/661729658250/VTSP:(0/3/0):-1:1:1/vtsp_play_busy_timer_start:
   Timer Start Time=19113500, Busy Timer Value=30(ms)
   Tone=Number Unobtainable, Tone Timeout=30(s), Progress Indication Sent=0
Configure "no battery-reversal" under voice-port.
Done but we still have the same issue. Whn making inbound calls, i hear a single ring then line goes busy
voice-port 0/1/0
no battery-reversal
connection plar opx 5300
caller-id enable
voice-port 0/1/1
no battery-reversal
connection plar opx 5301
caller-id enable
CCME#term mon
CCME#
*Mar  3 12:14:51.014: htsp_process_event: [0/3/0, FXOLS_ONHOOK, E_DSP_SIG_0000]f        xols_onhook_ringing
*Mar  3 12:14:51.014: htsp_timer - 125 msec
*Mar  3 12:14:51.142: htsp_process_event: [0/3/0, FXOLS_WAIT_RING_MIN, E_HTSP_EV        ENT_TIMER]fxols_wait_ring_min_timer
*Mar  3 12:14:51.142: htsp_timer - 10000 msec
*Mar  3 12:14:52.066: htsp_process_event: [0/3/0, FXOLS_RINGING, E_DSP_SIG_0100]
*Mar  3 12:14:52.066: fxols_ringing_not
*Mar  3 12:14:52.066: htsp_timer_stop
*Mar  3 12:14:52.066: htsp_timer_stop3 htsp_setup_ind
*Mar  3 12:14:52.066: [0/3/0] get_local_station_id calling num= calling name= ca        lling time=03/03 12:14  orig called=
*Mar  3 12:14:52.066: //-1/xxxxxxxxxxxx/VTSP:(0/3/0):-1:-1:-1/vtsp_allocate_cdb:
   CDB=0x67B2D700
*Mar  3 12:14:52.066: //-1/xxxxxxxxxxxx/VTSP:(0/3/0):-1:-1:-1/vtsp_do_call_setup        _ind:
   Progress Indication=3, CarrierIDCode=, Info Trans Capability=144, Source Carr        ier ID=, tg_label_flag=0
*Mar  3 12:14:52.066: //-1/34652DD18290/VTSP:(0/3/0):-1:-1:-1/vtsp_do_normal_cal        l_setup_ind:
*Mar  3 12:14:52.066: //-1/34652DD18290/VTSP:(0/3/0):-1:-1:-1/vtsp_timer:
   Timer Start Time=19490708, Timer Value=180000(ms)
*Mar  3 12:14:52.070: //-1/34652DD18290/VTSP:(0/3/0):-1:-1:-1/vtsp_insert_cdb:
*Mar  3 12:14:52.070: //-1/34652DD18290/VTSP:(0/3/0):-1:1:1/vtsp_dsm_opened_cb:
*Mar  3 12:14:52.070: //-1/34652DD18290/VTSP:(0/3/0):-1:1:1/vtsp_process_event:
*Mar  3 12:14:52.070: //-1/34652DD18290/VTSP:(0/3/0):-1:1:1/act_setup_ind_pend_s        uccess:
*Mar  3 12:14:52.070: //-1/34652DD18290/VTSP:(0/3/0):-1:1:1/vtsp_realloc_cdb:
   CDB=0x67B2D700
*Mar  3 12:14:52.070: //-1/34652DD18290/VTSP:(0/3/0):-1:1:1/vtsp_indicate_call:
*Mar  3 12:14:52.070: //191/34652DD18290/VTSP:(0/3/0):-1:1:1/vtsp_insert_cdb:
*Mar  3 12:14:52.070: //191/34652DD18290/VTSP:(0/3/0):-1:1:1/vtsp_timer:
*Mar  3 12:14:52.074: //191/34652DD18290/VTSP:(0/3/0):-1:1:1/vtsp_report_digit_c        ontrol:
*Mar  3 12:14:52.074: //191/34652DD18290/VTSP:(0/3/0):-1:1:1/vtsp_process_event:
*Mar  3 12:14:52.074: //191/34652DD18290/VTSP:(0/3/0):-1:1:1/act_setup_ind_ack:
*Mar  3 12:14:52.074: //191/34652DD18290/VTSP:(0/3/0):-1:1:1/vtsp_timer_stop:
   Timer Stop Time=19490709
*Mar  3 12:14:52.078: htsp_process_event: [0/3/0, FXOLS_WAIT_SETUP_ACK, E_HTSP_S        ETUP_ACK]
*Mar  3 12:14:52.078: fxols_wait_setup_ack:
*Mar  3 12:14:52.078: [0/3/0] set signal state = 0xC timestamp = 0fxols_check_au        to_call
*Mar  3 12:14:52.350: htsp_process_event: [0/3/0, FXOLS_PROCEEDING, E_DSP_SIG_01        10]fxols_rvs_battery
*Mar  3 12:14:52.350: htsp_timer_stop2
*Mar  3 12:15:02.074: //191/34652DD18290/VTSP:(0/3/0):-1:1:1/vtsp_report_digit_control:
*Mar  3 12:15:02.074: //191/34652DD18290/VTSP:(0/3/0):-1:1:1/vtsp_process_event:
*Mar  3 12:15:02.074: //191/34652DD18290/VTSP:(0/3/0):-1:1:1/act_pre_con_disconnect:
*Mar  3 12:15:02.074: //191/34652DD18290/VTSP:(0/3/0):-1:1:1/vtsp_timer_stop:
   Timer Stop Time=19491709
*Mar  3 12:15:02.074: //191/34652DD18290/VTSP:(0/3/0):-1:1:1/vtsp_ring_noan_timer_stop:
*Mar  3 12:15:02.074: //191/34652DD18290/VTSP:(0/3/0):-1:1:1/vtsp_play_busy_timer_start:
   Timer Start Time=19491709, Busy Timer Value=30(ms)
Below is the output in the OUTBOUND direction. The line in red looks interesting
*Mar  3 12:21:51.322: digit_strip:1, pcn:90721432454, poa:9T
*Mar  3 12:21:51.322: pcn:0721432454, poa:T
*Mar  3 12:21:51.322: Final pcn:0721432454, poa:T, dial_string:9,0721432454
*Mar  3 12:21:51.322: //196/2BD2D909829A/VTSP:(0/1/1):-1:1:1/vtsp_create_call_active_on_setup_req:
   Target Carrier ID=
*Mar  3 12:21:51.326: //196/2BD2D909829A/VTSP:(0/1/1):-1:1:1/vtsp_create_call_active_on_setup_req:
   Source Carrier ID=htsp_setup_req
*Mar  3 12:21:51.326: //196/2BD2D909829A/VTSP:(0/1/1):-1:1:1/vtsp_request_call:
   Progress Indication=3, Info Trans Capability=0
   Calling Number=5324, TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed
   Called Number=90721432454, TON=Unknown, NPI=Unknown
*Mar  3 12:21:51.326: htsp_process_event: [0/1/1, FXOLS_ONHOOK, E_HTSP_SETUP_REQ]fxols_onhook_setup
*Mar  3 12:21:51.326: [0/1/1] set signal state = 0xC timestamp = 0
*Mar  3 12:21:51.326: htsp_timer - 1300 msec
*Mar  3 12:21:51.326: //196/2BD2D909829A/VTSP:(0/1/1):-1:1:1/vtsp_process_event:
   [state:S_SETUP_REQUEST, event:E_TSP_PROCEEDING]
*Mar  3 12:21:51.326: //196/2BD2D909829A/VTSP:(0/1/1):-1:1:1/act_setup_pend_proceeding:
*Mar  3 12:21:51.326: //196/2BD2D909829A/VTSP:(0/1/1):-1:1:1/vtsp_timer:
   Timer Start Time=19532634, Timer Value=10000(ms)
*Mar  3 12:21:51.330: //196/2BD2D909829A/VTSP:(0/1/1):-1:1:1/act_setup_pend_proceeding:
   Peer=2, Progress Indication=0, Return Code=2
*Mar  3 12:21:51.334: //196/2BD2D909829A/VTSP:(0/1/1):-1:1:1/vtsp_dsm_opened_cb:
*Mar  3 12:21:51.334: //196/2BD2D909829A/VTSP:(0/1/1):-1:1:1/vtsp_process_event:
   [state:S_NULL, event:E_VTSP_DSM_OPEN_SUCCESS]
*Mar  3 12:21:51.334: //196/2BD2D909829A/VTSP:(0/1/1):-1:1:1/act_setup_req_wait_pend_success:
   Event=72
*Mar  3 12:21:51.334: //196/2BD2D909829A/VTSP:(0/1/1):-1:1:1/vtsp_timer_stop:
   Timer Stop Time=19532635
*Mar  3 12:21:51.578: htsp_process_event: [0/1/1, FXOLS_WAIT_DIAL_TONE, E_DSP_SIG_1100]fxols_power_denial_proc
*Mar  3 12:21:51.578: htsp_timer2 - 1000 msec
*Mar  3 12:21:51.578: htsp_timer_stop
*Mar  3 12:21:52.578: htsp_process_event: [0/1/1, FXOLS_WAIT_DIAL_TONE, E_HTSP_EVENT_TIMER2]fxols_timer2_proc
*Mar  3 12:21:52.578: htsp_timer_stop
*Mar  3 12:21:52.578: htsp_timer_stop2
*Mar  3 12:21:52.578: [0/1/1] set signal state = 0x4 timestamp = 0
*Mar  3 12:21:52.578: //196/2BD2D909829A/VTSP:(0/1/1):-1:1:1/vtsp_process_event:
   [state:S_SETUP_REQ_PROC, event:E_TSP_DISCONNECT_IND]
*Mar  3 12:21:52.578: //196/2BD2D909829A/VTSP:(0/1/1):-1:1:1/act_setup_pend_release_ind:
   Cause Value=34
*Mar  3 12:21:52.578: //196/2BD2D909829A/VTSP:(0/1/1):-1:1:1/vtsp_ring_noan_timer_stop:
   Timer Stop Time=19532759
*Mar  3 12:21:52.578: //196/2BD2D909829A/VTSP:(0/1/1):-1:1:1/vtsp_cc_call_disconnected:
   Cause Value=34
*Mar  3 12:21:52.578: //196/2BD2D909829A/VTSP:(0/1/1):-1:1:1/vtsp_set_release_source:
   Release Direction=PSTN, Release Source=Called Party-PSTN
   Peer=2
*Mar  3 12:21:52.578: //196/2BD2D909829A/VTSP:(0/1/1):-1:1:1/vtsp_call_disconnect:
   [Out Of Service]-Tone Played In Direction [Both]
Which country is this?
Also set "no supervisory disconnect signal"
Probably it's not a professional answer but sometimes some bugs are solved by rebooting.
Multiservice Voice Debug Lookup page suggests also:
Show voice trace
Basic Debugs
debug voip ccapi inout
debug vpm signal
debug voip vtsp default
debug voip vtsp session
Advanced Debugs
debug voip dspapi all
debug voip hpi all
debug voip vtsp all
debug dsprm all
