Dial-peer pots sometimes it works and some others times it doesnt? also it works on some phone and not other phones
heshamcentrino
Dear All,
In 2951 Router with CUCME  12.0 and 3 8865 Phone registered to it.
I have a local landline thats connected to voice-port 0/0/0 and an Obihaltalk connected to voice-port 0/0/1 that has google voice configured. The setup works well but my problem here the dial-peer pots sometimes its applied and some other times its not working?? What could be the problem?
Here you are my configuration
I appreciate all your help
5 Replies 5
Chris Deren
What country is this in?  Looking at dial-peers 2 and 3 they are overlapping which may cause issues depending on what you are dialing.  I would suggest capturing "debug voice ccapi inout" for the failed call, which will tell us what is being matched.
Hi Chris,
Thanks for your reply. for dial-peer 1 this is designed for UK , Dial-peer 2 and 3 are made for NANP
Dial-peer 1 meant for 9.1[10 digits] and dial-peer 2 meant for 9.[10 digits]
the first XXX1 phone works good but other phone are not working well. I can delete dial-peer 3 and try
Chris it has nothing to do with the dial-peers too. I have tried to call internally from 1001 to 1003 and here you the results for your informatoin both phones are 8865
Cisco router 2951 IOS Version Version 15.0(1r)M16 , flash:c2951-universalk9-mz.SPA.157-3.M5.bin
Mar 19 01:46:02.880: //-1/39A864BBACFA/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=1001
----- ccCallInfo IE subfields -----
cisco-ani=1001
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=1
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
Mar 19 01:46:02.880: //-1/39A864BBACFA/CCAPI/cc_api_call_setup_ind_common:
Interface=0x2BB7298, Call Info(
Calling Number=1001,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=1(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=FALSE,
Incoming Dial-peer=40002, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=11300
Mar 19 01:46:02.880: //-1/39A864BBACFA/CCAPI/ccCheckClipClir:
In: Calling Number=1001(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Out: Calling Number=1001(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Mar 19 01:46:02.880: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Mar 19 01:46:02.880: :cc_get_feature_vsa malloc success
Mar 19 01:46:02.880: cc_get_feature_vsa count is 1
Mar 19 01:46:02.880: :FEATURE_VSA attributes are: feature_name:0,feature_time:399469304,feature_id:126
Mar 19 01:46:02.880: //11300/39A864BBACFA/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=1001(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=1(TON=Unknown, NPI=Unknown))
Mar 19 01:46:02.880: //11300/39A864BBACFA/CCAPI/cc_process_call_setup_ind:
Event=0x16C6D710
Mar 19 01:46:02.880: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 1
Mar 19 01:46:02.884: //11300/39A864BBACFA/CCAPI/ccCallSetContext:
Context=0x3FC1568
Mar 19 01:46:02.884: //11300/39A864BBACFA/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 11300 with tag 40002 to app "_ManagedAppProcess_Default"
Mar 19 01:46:02.884: //11300/39A864BBACFA/CCAPI/ccCallSetupAck:
Call Id=11300
Mar 19 01:46:02.884: //11300/39A864BBACFA/CCAPI/cc_api_set_transfer_info:
Transfer Number=, Transfer Reason=0x0
Mar 19 01:46:02.884: //11300/39A864BBACFA/CCAPI/ccSetDigitTimeouts:
Initial Digit Timeout=10000(ms), Inter Digit Timeout=10000(ms)
Call Entry(Inter Digit Timeout=10000(ms), Initial Digit Timeout=10000(ms))
Mar 19 01:46:02.884: //11300/39A864BBACFA/CCAPI/ccCallReportDigits:
(callID=0x2C24, digit_event=0x1, enable=TRUE, consume=FALSE)
Enabled=TRUE, Call Id=11300
Mar 19 01:46:34.884: //11300/39A864BBACFA/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x2BB7298, callID=0x2C24, disp=-4, digit_event=0x1, enable=TRUE, consume=FALSE)
Enabled=TRUE, Disposition=0xFFFFFFFC, Interface=0x2BB7298, Call Id=11300
Call Entry(Initial Digit Timeout=10000(ms), Inter Digit Timeout=10000(ms))
Mar 19 01:46:34.884: //11300/39A864BBACFA/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Mar 19 01:46:34.892: //11300/39A864BBACFA/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x2BB7298, Tag=0x0, Call Id=11300,
Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Call Disconnect Event Sent
Mar 19 01:46:34.896: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Mar 19 01:46:34.896: :cc_free_feature_vsa freeing 17CF6AF0
Mar 19 01:46:34.896: vsacount in free is 0
HeshamCentrino#show voice reg
HeshamCentrino#show voice register gl
HeshamCentrino#show voice register global
CONFIG [Version=12.0]
Version 12.0
Mode is cme
Auto-registration is enabled
Max-pool is 10
Max-dn is 20
Outbound-proxy is enabled and will use global configured value
Security Policy: DEVICE-DEFAULT
Forced Authorization Code Refer is enabled
Source-address is CME Address port 5060
Load 8865 is sip8845_65.12-0-1-11
Authenticate register
NTP Server Address is CME Address
NTP Server Mode is: directedbroadcast
Time-format is 12
Date-format is M/D/Y
Time-zone is 21
Hold-alert is disabled
Mwi stutter is disabled
Mwi registration for full E.164 is disabled
Forwarding local is enabled
Video is enabled
Camera is enabled
Privacy is enabled
Privacy-on-hold is disabled
Conference hardware is disabled
Dst auto adjust is enabled
start at Apr week 1 day Sun time 02:00
stop at Oct week 8 day Sun time 02:00
Max redirect number is 5
IP QoS DSCP:
ef (the MS 6 bits, 46, in ToS, 0xB8) for media
cs3 (the MS 6 bits, 24, in ToS, 0x60) for signal
af41 (the MS 6 bits, 34, in ToS, 0x88) for video
default (the MS 6 bits, 0, in ToS, 0x0) for service
Telnet Level: 0
Tftp path is flash:/its
Generate text file is enabled
Tftp files are created, current syncinfo 0054334230633958
OS79XX.TXT is not created
timeout interdigit 10
timeout transfer recall 0
network-locale[0] US (This is the default network locale for this box)
network-locale[1] US
network-locale[2] US
network-locale[3] US
network-locale[4] US
user-locale[0] US (This is the default user locale for this box)
user-locale[1] US
user-locale[2] US
user-locale[3] US
user-locale[4] US
MWI unsolicited notify is disabled
Active registrations : 3
Total SIP phones registered: 3
Total Registration Statistics
Registration requests : 14
Registration success : 7
Registration failed : 7
unRegister requests : 4
unRegister success : 4
unRegister failed : 0
Auto-Register requests : 0
Attempts to register
after last unregister : 0
Last register request time : 22:55:26.512 GMT Wed Mar 18 2020
Last unregister request time : 08:33:28.078 GMT Wed Mar 18 2020
Register success time : 22:55:26.512 GMT Wed Mar 18 2020
Unregister success time : 08:33:28.079 GMT Wed Mar 18 2020
HeshamCentrino#
Thanks for your help
From the debug it looks like single digit was dialed "1", how did you dial enblock or digit by digit?
One thing you are missing is inbund voip dial-peer, can you add something like:
dial-peer voice 10 voip
description CME - Inbound
session protocol sipv2
incoming called-number .
codec g711ulaw
dtmf-relay sip-notify rtp-nte
ip qos dscp cs3 signaling
no vad
You also mention it works from some phones and not others, can you point which one it works for and which one it does not? Are all your phones SIP phones or are there SCCP as well?
Viewing full config would be helpful as I dont see what you have under "voice service voip" or "sip-ua"
codec g711ulaw
no vad
Thank you very much Chris
I just dialed 1003 and pressed Speaker and it wasn't ringing. Sometimes it works and sometimes it doesn't
This happens in all the phone. I have 3 8865 phones and the same thing happens
I wonder why do we need an inbound dial-peer? I did the PLAR to my phone and works well. Incoming calls , I don't have any issues at all. The incoming calls on both UK Landline and OBItalk works perfectly with the ID and everything
All my phones are SIP phone and I don't have any telephony-service activated only 8865 phones
Here you are all the entire config
