05-14-2008 12:19 AM - edited 03-15-2019 10:39 AM
With regard to the dial peer preference on the router ,we have configured two dial-peers with different session targets and preference. The system seems to be always prefering the dial-peer which is in the first order in router`s configuration.The preference does`nt seem to be actually making any difference.We were able to failover to the second dial-peer if the first dial-peer is kept shut.Could somebody advise on the solution ,if you had come across this ever?
Note : The calls are being tried through the csim start from the router itself.
Hardware Platform : 3845
Software Platform : 12.4(15)T3
Raj
05-14-2008 01:53 AM
Just to add to it ,the dial-peers are sip dial-peers and is being configured for the redundancy purpose.
Raj
05-14-2008 07:38 AM
can you post the dial-peers?
javalenc
05-14-2008 07:58 AM
Here you go !!!
dial-peer voice 101 voip
description To Reach CallServer
translation-profile incoming block
preference 1
destination-pattern 6500
session protocol sipv2
session target ipv4:10.10.10.60:5060
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 102 voip
preference 2
session target ipv4:10.10.10.61:5060
dtmf-relay rtp-nte
codec g711ulaw
no vad
sip-ua
retry invite 1
timers expires 60000
reason-header override
05-14-2008 09:44 AM
you would need to run a debug voip ccapi inout to determine if indeed the dial-peers are being used as you mention
javalenc
if this helps, please rate
05-14-2008 01:25 PM
The default behavior is that the longest matching dial peer supersedes the preference value.
To change it, you can enter "dial-peer hunt 2" in telephony-service.
Nico
05-14-2008 09:08 PM
I have already tried this with no luck ,as it always prefer the dial-peer 101 and fails over to 102 ,only when the dial-peer is kept shut.Please note that I have the same destination pattern on both of the dial-peers.
Raj
05-15-2008 04:30 AM
Hi Raj,
In the configuration you posted, dial-peer 101 has a lower preference (and therefore is the preferred dial-peer) than dial-peer 102. Can you confirm that you have you have indeed tried configuring a lower preference on dial-peer 102 to cause it to be the preferred dial-peer?
Michael.
05-15-2008 06:58 AM
Hi Mike,
I have tried that already and was hitting the 101 dial-peer only.
Raj
05-15-2008 07:06 AM
Thanks Raj,
Any chance you can post here the output of 'debug voip dialpeer all' collected when recreating the problem?
Michael.
05-15-2008 10:25 AM
Try "preference 10" on DP 101 an "default preference" on 102.
Maybe the "max-con" can help as well.
Greets
05-15-2008 10:39 PM
05-15-2008 10:36 PM
05-16-2008 12:54 PM
Hi Raj,
My apologies for the delayed response here. Today's been a busy day. Thanks for capturing and posting your debugs. The observation from the traces is that both dial-peers are indeed candidates for routing the call, but 101 is being selected regardless of the preference on dial-peer 102. My suspicion (and I haven't verified this in the lab) is that the results will be different if the test was an actual call, and not a 'csim start'. Have you had the opportunity to verify if this is the case or if the result is different when there is an inbound dial peer involved before the call is sent out of 101/102?
Michael.
05-16-2008 01:02 PM
I think Michael's suspicion is right. csim doesn't observe all the settings under a DP, for example, it doesn't apply translation-profile. So that could be the issue here.
