Dial Peer Shutdown
clark white
Level 2
Level 2
Attached is the running config.
Call gets disconnected and the fast busy tone comes when user try to dial after disconnect this is happening everyday , when i try to troubleshoot  i see the below error in the logging buffer continuously.
IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (96/100).
     Call (callID=1525154) is rejected
I have noticed that when i shut the dial-peer for the CUCM-SUB everything works fine, the errors in the logging buffer also stops when i enable the dial-peer the logging buffer gets full by the above logs
sh proc cpu
CPU utilization for five seconds: 98%/8%; one minute: 97%; five minutes: 58%
PID Runtime(uS)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
285  1593408000     1157748       1376 49.91% 50.67% 30.76%   0 CCH323_CT
122   412276000     1304031        316 14.79% 14.68%  8.80%   0 IP Input
157    36928000      559448         66  3.67%  4.48%  2.68%   0 TCP Timer
7 Replies 7
Jorge Armijo
Level 4
Level 4
Hi Clark,
You can additionally gather the "show proc cpu sorted" so we can see what is the proccess that is consuming more CPU. Also, you can gather "show procces memory" to check the memory utilization.
Can you share the "show tech" from the router? We will have a better idea of the current setup.
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
Dears
Here is the Attached,
But all comes normal when i shut the dial-peer for secondary CUCM. I think there is a loop. Can anybody put more shade.
Hi Clark,
Confirmed that the proceess:
CCH323_CT
is the one that consumes the highest resources on the Router. Could you post the complete "show tech"?
I can see only a couple of voip dial-peers, and to be honest, only 3 h323 voip dial-peers willnot cause the CPU to increase close to the 99% of utilization.
Perhaps, the router is receiving tons of H323 requests and is causing the high cpu utilization.
Jorge Armijo
brmeade
Level 4
Level 4
Clark,
Sounds like a call loop or something similar.
Brian
Agree Brian...
However, the piece of config on the post is not reflecting an obvious call loop, sure enough with a full config and/or a detailed debug we will see it
Jorge Armijo
Hello Jorge,
That is the only config in my  router i will add one more extra infomation that i have 2 No's E1 PRI  link, will it cause any conflict ??? or any special commands to be executed if we have 2 No's PRI
I will provide you the sh tech as soon as possible.
Thank
Hi Clark.
Can you please post a debug voice ccapi inout during a call setup?
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
