01-13-2015
09:20 AM
- last edited on
03-25-2019
08:33 PM
by
ciscomoderator
I am setting up a fax system. A PRI will come into a router which will connect to a rightfax server via sip. I have a DID range on the rightfax server of let say (385) 555-xxxx. So do I need a voip peer and a pots peer to get the calls from the PSTN to the voip server? Can I use generic peers or do I have to matched explicitly. any help would be appreciated.
Solved! Go to Solution.
01-13-2015 01:23 PM
Yes you should set up pots dial peer to atch inbound call and a voip dial-peer for outbound calls to your sip server.
Default dial-peers have a lot of limitations and the config on default dial perrs can not be changed.
Refer to this doc:
http://www.cisco.com/c/en/us/support/docs/voice/call-routing-dial-plans/14074-in-dial-peer-match.html#intro
-Terry
Please rate all helpful posts and amtk the thread answered if you have no other queries
01-13-2015 01:23 PM
Refer to this doc:
-Terry
