07-23-2012 01:23 AM - edited 03-16-2019 12:19 PM
I have CUCM 8.6, and I have installed Cisco Jabber on my cellphone. It works fine when I dial numbers without +,
but when I try to dial number from my directory that starts with +, it fails. I am using H.323 protocol on gateway.
Does anyone know what I should do to make possible dialing numbers that starts with +?
Thanks a lot,
Svetomir
Solved! Go to Solution.
07-23-2012 01:49 AM
You have two options:
1) Set up Application Dial Rules to map + numbers to the numbers that you can actuall dial from your handsets currently. Remember once you have configured the rules to run the cmterm-cupc-dialrule-wizard-0.1.cop.sgn to generate the TFTP file from those rules that the Jabber clients need.
- or -
2) Configure your CUCM to support + dialling fully. This would probably be much more complicated...
I'd go for option 1 as it's probably going to be simpler.
Principal Engineer at Logicalis UK
Please rate helpful posts...
07-23-2012 01:49 AM
- or -
07-23-2012 02:43 AM
Hi Aaron, thanks for the reply. I have actually tried something like the 1. option. I made an app. dial rule like this:
I wanted to dial +38163XXXXXX. But it didn't work.
Now, I do not understand what should I do with cmterm-cupc-dialrule-wizard-0.1.cop.sgn, or what should I change in my app. dial rule.
I appreciate your help. Thanks
07-23-2012 05:17 AM
Hi Svetomir,
What is your country?
I mean, if your application dial rule removes the + sign, then you left with 38163XXXXXX, but I doubt you need to add something to that number before being able of sending it to PSTN, e.g.:
add 00 to have 0038163XXXXXX or 01138163XXXXXX
Can you check if the call arrives to VG? and if yes, in what format?
