DialPlan generator
Hi everyone,
This question is maybe a kind of out this forum topic but this is my last resort. I have been searching for application or excel macro to help me to generate a dialplan based on a list of DN or Pstn number. When I said "generate a dialplan" it means decrease the amount of number that can be in a list putting together the number as in a range. For example:
I have all this number:
DN + PST Numbers List
4001
4002
4003
5001
5002
7004
18002262727
18002262728
18002262729
Result expected:
4001-4003
5001-5002
7004
18002262727 - 18002262729
In real world, I have to do the same but with more than 7,000 number that's why asking for help...
Please rate all useful posts
Favor calificar todos las respuestas útiles.
_____________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
MDGDP, CCNA, CCNA Voice certified
__________________________________________________
Please remember to rate useful posts clicking on the stars below.
6 Replies 6
will.alvord
Level 5
Level 5
I'm not familiar with an automated tool, but what about a route plan report export to excel with sorting followed by manually identifying ranges.  Unless someone else has found or developed something automagic, that's as good as you're going to get.
Hi Will, thanks for the answer but at the end what I don't want to do is identifiyng range automatly...
Any thought?
Any help? Look like I will have to spend my weekend playing with number
I was thinking about this over the weekend and it seems like you could do it programmatically - maybe even an excel macro.  You basically just run down the pattern column of a route plan report csv output and compare the current value with the previous value to see if the current value is previous+1 to signify number ranges (if that makes sense).  There will be special cases for square brackets, dots, x's, bangs, etc.  I just don't have the time to try it.  Might be enough to get you started though.  Sorry I couldn't be more help.
I already found a solution. This two formula make the trick:
=IF(ROWS($A$1:A1)=1,INDEX(List,1),INDEX($A$2:$A$228,SMALL(IF($A$3:$A$228-$A$2:$A$227>1,ROW($A$3:$A$228)-MIN(ROW($A$3:$A$228))+2,""),ROW(A1)-1)))
=IF(SUM(IF($A$3:$A$228-$A$2:$A$227>1,1,""))=ROW(A1)-1,INDEX(List,COUNT(List)),INDEX($A$2:$A$227,SMALL(IF($A$3:$A$228-$A$2:$A$227>1,ROW($A$3:$A$228)-MIN(ROW($A$3:$A$228))+1,""),ROW(A1))))
Can I give me a +5?
