DID and Hunt Pilot
Sonam
Can we make Hunt Pilot a DID? Because i am trying to make hunt pilot DID so that outside callers can call directly Hunt pilot number and then to Hunt list and to Line Group. In nutshell , It will act as a ccx.
Is this possible?
Dennis Mink
Yes, yes and yes, it is possible.
treat it the same as an extension on your phone. so if you have say a 100 number range DID and you use like 4XXX as your internal extensions. the for instance 4001 can be a hunt pilot, 4003 a phone etc etc.
Please remember to rate useful posts, by clicking on the stars below.
Thank you Mr. Dennis.
I will update you after trying it .
dont hesitate to add to this post if you cant get it to work, and provide example of your number plan,. this shouldnt be to hard to achieve.  cheers
