DID mapping with PRI
@Syed
Level 3
Level 3
Dear Friends,
Need a help on DID mapping with PRI.
  1. Phones are registered to cucm 11.5, we have 2 E1 PRI lines (Pri & Sec). Primary PRI is used for inbound calling and secondary is only for outbound calling.
  2. I have configured route group and given priority to secondary PRI for outbound and it is working fine, but unable receive inbound calls.
  3. It is an MGCP gateway registered to CUCM.
  4. Phone are configured with 4 digits extension. (Example: 1000, 2000, 2999 etc.).
  5. DID range is from 1000 – 2999 (two thousand DIDs).
  6. I have created translation pattern for incoming calls 06411xxxx translating to xxxx.
  7. When dialing out from mobile phone to DIDs call is hitting the gateway but I am seeing unallocated/unassigned cause code in q931 logs.
I am sure this is purely lack of configured issue, please guide me with this as to how I could achieve the above task.
Thank you in advance
Syed
2 Accepted Solutions
Jaime Valencia
Most likely a basic call routing issue, CSS/partitions
FYI there's no need for any TP, that's what significant digits are for.
java
if this helps, please rate
share the following the debugs while make a test call.
debug isdn q931
debug mgcp events
debug mgcp packets
Also, share the calling and called numbers
Jaime Valencia
java
Removed TP, but significant digits are not helping me.
debug isdn q931
debug mgcp events
debug mgcp packets
It is now working.
Thank you for your support and help
