Difference between MCS-7845-H2-RC2 & MCS-7845-H2-IPC2 ?
khanfawaz
I want to know, what does the "RC2" mean in MCS-7845-H2-RC2. I want to know whether CUCM 7.0 or CUCM 7.1.5 can be installed on MCS-7845-H2-RC2? Is there any data sheet which shows CUCM 7.0 or CUCM 7.1.5 can be installed on MCS-7845-H2-RC2? What does the terminology RC2 and IPC2 stands in MCS-7845-H2-RC2 &  MCS-7845-H2-IPC2 exactly?
13 Replies 13
Gordon Ross
Level 9
Level 9
As far as I'm aware, there is no difference. I believe the suffixes indicate what software the box was original bought to run (e.g. CUCM, CUPM, CUPS, etc)
The page at
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html
details what's supported on what.
GTG
Please rate all helpful posts.
Perfect response Gordon, you beat me to it :-) Thats worth 5 stars!
Harmit.
Hi Ross,
Thanks for the reply.
I am also thinking the same way. I have that link with me, but in that link it does not say we can install CUCM 7.X on MCS-7845-H2-RC2.
There are different part names for MCS-7845-H2 servers. All their hardware capability are identical. I have screen shot for that.
In that link I posted, just look for MCS-7845-H2.
The 7845-H2s are supported for CUCM 7, 8 & 9 (Although you *may* need to upgrade RAM & HDs)
I'm certainly running my 8.6 cluster on 7845-H2 boxes.
GTG
Harmit Singh
Hi khanfawaz,
MCS-7845-H2-IPC2 can be broken down into the following:
MCS-7845     -->     Server Hardware Identifier (Model)
H2                -->     HP 2nd Generation
IPC2             -->     2nd Generation Chassis supported by the CUCM Business Unit.
All the below MCS servers have the same config, but the chassis are labeled by different business units (BUs) for different products.
DL380-G5 Server
2x Xeon 5140 2.33GHz Processor
4G RAM
4x 146GB Hard Drives
MCS-7845-H2-IPC2
MCS-7845-H2-CCX2
MCS-7845-H2-CCE2
MCS-7845-H2-MOB1
MCS-7845-H2-RC2
Having said that, from what I remember, different BUs ship out these servers bundled with the software. Also, the BIOS, RAID, HDD versions may vary depending on the need for the application for which the server was intended to be used for. You can refer to the following link which shows that RC1/RC2 is not there in the table for any version of CUCM out there:
HTH.
Regards.
Harmit.
But don't worry about changing use, as the software installer will set all necessary RAID, firmwares, etc as part of the install.
GTG
Rob Huffman
Hi Khanfawaz,
Gordon is right on the money here +5 buddy!
Here's the breakdown;
Ordering Information for Spare Servers by Application
Application
Spare Part Number
Cisco Unified Application Environment
MCS-7845-H2-IPC2
Cisco Unified Communications Manager
MCS-7845-H2-IPC2
Cisco Emergency Responder
MCS-7845-H2-IPC2
Cisco Unified Presence
MCS-7845-H2-IPC2
Cisco Unified Contact Center Express
MCS-7845-H2-CCX2
Cisco Unified IP IVR
MCS-7845-H2-CCX2
Cisco Unified Intelligent Contact Management Enterprise
MCS-7845-H2-CCE2
Cisco Unified Intelligent Contact Management Hosted
MCS-7845-H2-CCE2
Cisco Unified Contact Center Enterprise
MCS-7845-H2-CCE2
Cisco Unified Contact Center Hosted
MCS-7845-H2-CCE2
Cisco IPICS
MCS-7845-H2-S31
Cisco Unified Customer Voice Portal
MCS-7845-H2-CCE2
Cisco Unified Expert Advisor
MCS-7845-H2-CCE2
Cisco Unified MeetingPlace conferencing
MCS-7845-H2-RC2
Cisco Unified MeetingPlace Express
MCS-7845-H2-RC2
Cisco Unity Unified Messaging
MCS-7845-H2-ECS3 (off-box unified messaging or voicemail)
(four 146-GB hard disk configuration)
MCS-7845-H2-ECS4 (on-box voicemail only)
(eight 145-GB hard disk configuration)
And here are the specs;
MCS-7845-H2-IPC2 HW Only MCS-7845-H2 with 4GB RAM
and Four 146GB SAS HD
MCS-7845-H2-RC2 HW Only MCS-7845-H2 with 4GB RAM
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/end_of_life_notice_c51-559678.pdf
I wouldn't see from this why CUCM couldn't be installed
Cheers!
Rob
"And if I should fall behind
Wait for me" - Springsteen
Rob Huffman
+5 to Harmit as well for his excellent response man...I am super slow today
Cheers!
Rob
Thanks Rob! +5 to you too, your reponse was bang on! :-)
Harmit.
David Hailey
The RC2 was an MPE bundle, whereas the IPC were generally bundled for CUCM, etc. HW specs looks to be the same.
HI Hailey,
Nice to see you here @ CSC so early after the big "Turkey Day" +5
Cheers!
Huff
Rob! What's up, man? There is plenty of turkey to go round here at home. Today should become Turkey Sandwich Day.
Thank You Gordon..
Thank You Harmit..
Thank You Rob..
Thank You David..
I have come to a conclusion now and I am going forward with CUCM 7.X installation on MCS-7845-H2-RC2.
