Difference between UCL Enhanced Plus vs. Enhanced
Daniel Gomez
I was wondering if anyone could help me out to clarify the actual difference between a UCL Enhanced Plus license and a UCL Enhaced.
I understand that the difference is that UCL Enhanced Plus supports two devices for 1 end user instead of one device for UCL Enhanced.
If that is correct, using Enhanced Plus allows:
1. Using a hard phone + Jabber?
2. Jabber could be any option (desktop for windows, for mac, iPhone, iPad, etc.)?
3. Could I configure all of the devices for the user and just use two of them simultaneously?
Daniel G.
7 Replies 7
Aman Soi
Hi Daniel,
I suppose if u configure more than two devices for a user, then it would be CUWL Standard and not Enhanced UCL Plus.
regds,
aman
islam.kamal
Level 10
Level 10
Hello
+5  for Aman. Kindly also find the below FYI.
Enhanced UCL:- This will allow for the client's deskphone. If the end user wants Jabber only in CTI controlled mode.
Enhanced UCL  Plus:- provides support for two Devices. Example. user A can operate two devices,  IP Phone and his Jabber Client on his iPad. user A will only consume a single UCL Enhanced Plus License in this scenario.
CUWL Standard:- provides for all the features included with the UCL Enhanced / Plus license level.
CUWL Standard provide support for more than two devices. I believe 10 devices remains the maximum keeping in line with UC9.0 CUWL Standard Licensing parameters.
please rate all useful information
Will the  Enhanced Plus license enough for VPN Less Jabber over expressway ?.
1 IP Phone device and second jabber over express way
Dear Eng. Islam
Is CUWL time-limited?
also
in Expressway E Pub and Sub
if I need to add more license for Rich Media Sessions, each license I buy
thank you so much
mdalsayed
If you purchased license through A flex, the license will be limited to the subscription durations.
RMS license will be shared between nodes in Expressway cluster.
Capacity licensing is done on a per-cluster basis, and all capacity licenses installed on a cluster peer are available to any peer in the cluster. This includes Rich Media Session licenses and room system & desktop system registration licenses.
Response Signature
Dear Nithin
hope you have a good day,
I don't know what is A flex? and can I buy life time CUWL License?
As I Know TelePresence Room, Enhanced 11.x and Enhance Plus 11.x licenses is a life time licenses. is it true?
mdalsayed
There is no perpetual license any more, all new license will be subscription based.
If you hold a perpetual license, you can use it.
Response Signature
