Differences between CCM versions
singh-ashok
What are the differences between CCM 3.3(5) & 4.2(3)?
What is the significant difference between CCM 4.1(3) & CCM 4.2(3)?
What are the major enhancements in CCM 6x compared to 4x versions?
2 Accepted Solutions
i can tell the major enhancemnts from 4 to 6 are:
the OS is red hut linux instead of MS windows
the database is IBM IDS instead of MS sql
the support of sip trunks
the abilty of subsecriber server to make write to some user facing feature while the bublisher down
the dhcp integrated with cusm instead of being separate service as it was with V4
abilty to integrate with service mobilty
version 4 also able to intergrate but need a saparte server for mobilty service
there is feature added to CFA called CFA override
this is what comes in my mind now
please, if helpful Rate
Hey Abhijit,
Long time buddy! Life is great, hopefully for you as well :)
"CFA Destination Override" is available in CCM 5.X and CCM 6.x. (this is a "one to one relationship between the CFWDALL Originator and Destination) Have a look;
Cisco Unified CallManager provides a service parameter (CFA Destination Override) that allows the administrator to override Call Forward All (CFA) when the target of the CFA calls the initiator of the CFA, so the CFA target can reach the initiator for important calls. In other words, when the user to whom calls are being forwarded (the target) calls the user whose calls are being forwarded (the initiator), the phone of the initiator rings instead of call forwarding back to the target. The override works whether the CFA target phone number is internal or external.
When the CFA Destination Override service parameter is set to False (the default value), no override occurs. Ensure the service parameter is set to True for CFA override to work. See Service Parameters Configuration in the Cisco Unified CallManager Administration Guide, Release 5.0(4), for information about configuring service parameters.
***Note: CFA override only takes place if the CFA destination matches the calling party and the CFA Destination Override service parameter is set to True. If the service parameter is set to True and the calling party does not match the CFA destination, CFA override does not take place, and the CFA remains in effect.
From this CCM 5.1.(1) doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a0080739bb8.html
New Features and Enhancements in Cisco Unity Express 3.2.1
New Language Support
Integration with Multiple Cisco Unified CME Sites
Nonsubscriber Recipients in Distribution Lists
Integrated Messaging Support for Apple Macintosh Users
PINless Login to Voice-Mail
Enhanced Installation Procedures and Increased Upgrade Paths
Password Synchronization Between Cisco Unity Express and Cisco Unified
Communications Manager Express
Login Banner Support for CLI Access
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel3_2/release/notes/rncue32.html
Hope this helps! Nice to talk again,
Rob
11 Replies 11
Steellllllllll0
I second that been looking for some good documentation which tables the differences apart from the basics...
Marwan & Rob,
Thanks a lot.
Ashok.
Rob Huffman
Hey Guys,
I put this together for someone a bit back :)
There have been new features added in each release between CCM 3.2 and CCM 4.3 I have tried to pick out the releases that had the biggest changes since CCM 3.2. These would be CCM 3.3(4), CCM 4.1(3) and CCM 4.2(1)Have a look;
CCM 3.3.4 New and changed Information
Forced Authorization Codes and Client Matter Codes
Cisco WebDialer
Cisco IP Telephony Backup and Restore System (BARS)
New and Updated Phone Support
Extension Mobility Enhancements
Cisco Security Agent
Dialed Number Analyzer (DNA)
Image Authentication
NM-HDV2 and NM-HD Support for Cisco CallManager
Conferencing Enhancements
Block External To External Transfer Service Parameter
International Dial Plan
Calling Search Space Enhancements
Default Trace Level Changed for Cisco Database Layer Monitor Service
http://www.cisco.com/en/US/products/sw/voicesw/ps556/prod_release_note09186a008020027c.html#wp1319190
CCM 4.1.3 New and changed Information
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/4_1/rel_note/413cmrn.htm#wp1708005
Cisco Unified CallManager Release 4.3(1), based on release 4.2(3), addresses the retirement of the MS Windows 2000 Operating System by enabling a migration of Cisco Unified CallManager to Windows Server 2003.
Because Cisco Unified CallManager Release 4.3(1) is based on release 4.2(3) refer to the Cisco Unified CallManager Documentation Guide for a list of documents that are related to Cisco Unified CallManager release 4.2 at the following URL:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_documentation_roadmaps_list.html
CCM 4.2.x New Features
New and Changed Information for Cisco CallManager Features CCM 4.2
The following sections describe new and changed information related to Cisco CallManager features:
Multilevel Precedence and Preemption Enhancements
Device Mobility
Cisco CallManager Attendant Console and Call Pickup Limitation
** Call Pickup Notification
** Directed Call Park
IPMA Enhancements
Cisco Messaging Interface Enhancements
Call Forwarding Enhancements
Password Management Features
** Log Out of Hunt Groups
** Voice-Mail-Related Changes to Hunt List and Hunt Pilot
New MLPP Service Lockout Enterprise Parameter
Phone Button Template
Call Diagnostics and Voice Quality Metrics
Overlap Sending and Receiving for H.323 Gateways
SDL Traces
Cisco CallManager T1 CAS Hookflash Transfer Support
From this doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/prod_release_note09186a00805f1470.html#wp2430214
....continued on next page
....from previous page
here is the related CCM 5.x and CCM 6.x info :)
Cisco CallManager 5.x Features
Call Park
Call Pickup Group
CTI and CTI Super Provider
Dynamic Host Control Protocol (DHCP)
International Dial Plans
LDAP Directory Enhancements
Licensing
Personal Directory Enhancements
Phone NTP References for SIP Phones
Presence
Roles and User Groups
RSVP
Service Enhancements
SIP Line Side (Endpoints) Support
SIP Route Pattern
SIP Third-Party Phones
SIP Trunk Enhancements
TFTP Enhancements
URL Dialing
Video Telephony Enhancements
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/5_0_1/501cmrn.html
Cisco Unified Communications Manager 6.0 feature enhancements:
•AAC/iLBC Voice Codec Support
•Advanced Ad Hoc Conference
•Audible Message Waiting Indicator
•Barge Enhancements
•Call Diagnostics and Voice Quality Metrics
•Call Forward Enhancements
•Call Forward All Calling Search Space Backward Compatibility
•Call Forward Overriding
•Call Pickup Notification
•Cisco Messaging Interface Enhancements
•Cisco Unified Communications Manager T1 CAS Hookflash Transfer Support
•Connected Number Display
•Credential Policy and User Authentication
•CTI Enhancements
•Device Mobility
•Directed Call Park
•Do Not Disturb
•Hold Reversion
•Intercom
•Licensing Enhancements
•Log Out of Hunt Groups
•Overlap Sending and Receiving for H.323 Gateways
•MGCP T.38 Enhancements
•Privacy on Hold
•Programmable Line Keys
•SCCP Optimization
•SDL Traces
•SIP Endpoints Support
•SIP Third-Party Phones Enhancements
•SIP Trunk Enhancements
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/6_0_1/601cmrn.html#wp44812
Hope this helps!
Rob
Rob,
Hope you are doing good buddy!
Thanks a lot again!!!
Just a few questions ( as usual :-)) -
Call forward override - was it introduced from CCM 5x? Can it be done for only one number or more than one?
One more completely unrelated question here -
What's the differnce between CUE 2.2 & CUE 3.1?
Take care,
Abhijit.
Hey Abhijit,
Rob
Rob,
Thanks again buddy. Have a great day.
Take care,
Abhijit.
u welcome
but rob is a leader this field :)
Brilliant...thanks !!
Great Job, Rob!!!
I was searching for this info for quite some time :-)
Tx a lot...
