Digiti Manipulation and Translation
Reynaldo Silva
Hi Guys!
I have a question about voice gateway.
My scenario is a voice gateway with 2 link (2 different ISP) to PSTN and one trunk to PBX.
I need the voice gateway decide what the ISP will follow the call, based on called number.
I Know, if the partner get include the digit, when i receive the call in voice gateway, i will remove the digit in dial-peer and follow to correct ISP, but the PBX,don´t have that feature and now,i need that decision is resolve in voice gateway.
Any idea?
7 Replies 7
Ayodeji Okanlawon
Are you saying you need to send the call to ISP based on the called number?
Sent from Cisco Technical Support Android App
Please rate all useful posts
yes, this is my scenario.
I dont see what the problem is. If the called number is different then configure the dial-peers to point to the correct ISP
"opportunity is a haughty goddess who waste no time with those who are unprepared"
OK, i think you don´t understand the problem.
Only to clear.The problem, is the router need to decide what the ISP will send the information, based on extension, and the extension is behind the PBX.
Ok..So you want to route calls based on calling number..You can use answer-address to achieve this..
dial-peer voice 5 pots
answer-address 5....
destination-pattern 9T
port 0/0/0:15
dial-peer voice  pots
asnwer-address 6....
port 0/0/1:15
You think i don´t need to use translation or some types of regex to include or retired digits?
You can do it in different ways..This is one of them and you can use voice translation rules too.
