03-06-2019 07:52 PM - edited 03-06-2019 07:57 PM
i have voice gateway that inbound PSTN number (02112345678) to CTI RP UCCX(99999), but my customer need to direct call from PSTN through to extension without get IVR from UCCX (02112345678*10000). can i achieve this configuration?
here is configuration for incoming call to CTI RP UCCX.
voice translation-rule 12
rule 1 /^\(02112345678\)/ /99999/
voice translation-profile INCOMING
translate called 12
dial-peer voice 200 voip
description ** Incoming from SIP PSTN **
translation-profile incoming INCOMING
session protocol sipv2
session target ipv4:x.x.x.x
incoming called-number .
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
voice-class sip options-keepalive up-interval 5 down-interval 5 retry 3
dtmf-relay rtp-nte
no vad
03-06-2019 08:51 PM
Considering that you have already configured the Directory Number 1000 on your system, you may replace on the voice translation-rule 12 command 99999 with 1000:
no rule 1 /^\(02112345678\)/ /99999/
rule 1 /^\(02112345678\)/ /1000/
George
03-07-2019 04:46 PM
03-07-2019 11:13 PM - edited 03-07-2019 11:30 PM
I got the impression that you want the direct line 02112345678 to ring on 1000 instead of 99999 and this is what I described above, wasnt it this case?
George
03-08-2019 07:10 PM
03-07-2019 05:32 AM
Just build proper translation patterns in CUCM to point the numbers where you want them to go.
