Direct Line Configuration
Syed Farhan Ali
Level 4
Level 4
Dear Techies,
We need to configure an Extension and Direct Line on a Cisco 7941 IP Phone. The following configuration has been done, but neither the calls are falling on the direct line nor we are able to use the direct line thorough the Line Button on the phone.
Following is the configuration, that we are doing on the Router.
New Configuration
voice translation-rule 6
 rule 1 // /021151/ dial-peer voice 23 voip
!  translation-profile incoming SFB
voice translation-profile SFB  answer-address 021151
 translate called 6
! dial-peer voice 30 pots
voice-port 0/2/0  destination-pattern 29T
 translation-profile incoming SFB  port 0/2/0
 supervisory disconnect dualtone mid-call
 timeouts call-disconnect 0
 timeouts wait-release 2
 connection plar 3xxx
 description "021151"
 bearer-cap Speech
 caller-id enable
dial-peer voice 10 pots
 incoming called-number 021151
 direct-inward-dial
 port 0/2/0
dial-peer voice 20 voip
 destination-pattern 021151
 progress_ind setup enable 3
 progress_ind progress enable 8
 session target ipv4:192.168.36.101
 codec g711ulaw
Can anyone, please help on this ?
Farhan.
14 Replies 14
Are the calls getting disconnected ? Collect the debugs for a test call and post it here.
Abhay Singh Reyal
The Only Way To Do Great Work Is To Love What You Do. If You Haven’t Found It Yet, Keep Looking. Don’t Settle
Are you using CUCM or CME ?
Abhay
Abhay Singh Reyal
Collect the debug voip ccapi inout and debug voip vtsp all.
Abhay
Abhay Singh Reyal
As per the debugs
Calling Number=021xxxx51(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=903458944401(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Incoming Dial-peer=23, Progress Indication=NULL(0), Calling IE Present=TRUE,
Calling number 021xxxx51 calls 903458944401 , and hits the Incoming Dial-peer 23.
Call gets disconnected as it is not able to find the outbound dial-peer
*Mar 28 05:46:32.043: //98/0045E2B1C002/CCAPI/ccCallDisconnect:
Cause Value=3, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Due to which the call does not get completed and gives an error code Cause Value=3, which is No route to destination (3). Configure the outbound dial-peer accordingly and test the call.
Abhay
Abhay Singh Reyal
As per this output that you have provided there are 4 dial-peers.
Called number is 903458944401, dial-peer 10 [Incoming] and 30 [Outgoing] which are Pots dial-peer, won't be matched as the number that you are dialing is not a match as per destination-pattern config.
Change the config accordingly and make a call.
Abhay
Abhay Singh Reyal
THanks
Provide the debugs for this new call.
Abhay
Abhay Singh Reyal
Chris Deren
Post full "show run" along with "debug voice ccapi inout".
