Directory access on CM5.1(1)
yanhui-wang
I have cm 5.1(1) integrated with AD and configure directory access point to CM.
When I press Directory button I got the list -- placed calls,...,personal directory, corporate directory. after I select "corporate directory", got an error message "HTTP 404.. page not found". However I tried all the urls with my browser, they work fine.
Any suggestions?
7 Replies 7
Chris Deren
It's most likely DNS issue, under Enterprise Parameters in Callmanager change all the hostname references to IP addresses to resolve your issues or make sure the CM servers were installed to use DNS.
Chris
gogasca
Level 10
Level 10
Could you please check the following:
Go to System> Enterprise parameter> under phone url parameter
check the value for directory> it should be something like:
http://x.x.x.x:8080/ccmcip/xmldirectory.jsp
If you see something different, please change it to above and replace the x with your CCM IP address. Remember that URL is case sensitive.
Then you need to stop/start the TFTP services and reset the phone to take affect
I already used IP address under "enterprise parameters" and also restart TFTP service, still tha same...
By the way, I used IP communicator for testing.
Hi yanhui-wang
I think it is a tftp block issue, something with ACLs.
ensure that all have full rights to the tftp
hth
/majdi
there is no ACL between communicator and CM, and I can browse the URL from the laptop where Communicator is running without any problem.
ever find an answer on this one? I've got a similar issue.
thanks,
matt
yes,
I used old IP Communicator, upgrade it can solve the problem.
